Disable AUTO light on Rear view mirror?
Hi
As the title suggests, does anyone know how to disable the AUTO light popping on each time on my rear view mirror? I have no need for such functions and i'd really like it to stay OFF.
Thanks.
Thanks.
AUTO function on the mirror is for the auto-dimming function for the rear view mirror. If you programmed the garage door opener to your buttons and want it disabled you can just reset/delete all codes using the buttons... I think it was something like holding the first and third one for 5 seconds
Oh - Looks like I had it mixed up from the get go. So its the auto dimming feature? I honestly don't notice anything different when Its on or off, however when I power it OFF, it only stays off until the car is turned off. Once turned back on, it just enables over and over. Any way to permanently disable?
Negative capt. You're over thinking it. Dark is dark. If you block the sensor there is no light. To prevent lights from the rear shining in your eyes it will darken when the front sensor gets no light.
At dusk cover the sensor w your hand for a couple minutes. You'll see it darken if it works!
Super Moderator
There are two light sensors, one facing the windshield, and the other facing the rear of the vehicle. The mirror darkens when the one facing the rear of the vehicle sees light, but the one facing the windshield doesn't. The confusion is that nosurprise is talking about covering the sensor that points towards the rear of the vehicle, while 2013FSport is talking about covering the one facing the windshield.
