2009 is 350 center console not working at all
Just got the car it doesn’t have nav the step below I’m guessing. I have no ac controls no radio no clock nothing comes on. Every fuse is good I pulled dash checked all connections what am I missing. I searched up an back and can’t find the answer for my system
Is it possible someone took the original nav system out of this car. It has the nav antenna but it’s an old system in the car. I’m starting to think I’ve been robbed
all connections are good power to everything when I did a vin check that model says it came with the navigation and I don’t have that system in the car. I guess call the dealer and find out if it was switched so I don’t buy the wrong thing
https://drivers.lexus.com/lexusdrivers/
Considering all connections are correct, car most likely came with the non-nav option as he stated. It probably got sent to auction because of the dead head unit/electrical/possible other issues. He can always try purchasing a used non-nav headunit off of eBay and checking if that works. If not, it'll be an electrical issue. If OP checked the fuses, then I'd lean on a dead HU.
Sam Khoury
06-03-03 01:50 PM
