Carbon build up
Well another way to help cut down the carbon deposits is to switch to motor oils that's are Dexos 1 Gen 2 approved. These oils just came out at the end of last year and help inhibit low carbon deposits due to less ash. Plus they are good for the LSPI issues that common OEM turbo vehicles were getting the past few years. All the fuel treatments I read about dont really do anything because the injectors dont spray over the valves in a GDI engine.
It is possible to do it your self. You will need a shop vac and a few other things but there was a guide either on here somewhere or I might of seen else where.
If you feel you don't have the ability to do it yourself, look for a VW/BMW Shop. They more than likely have a lot of experience doing Walnut Blasting.
Yea their definitely are signs..the most prominent one I know of is when the car is at a red light or just stopped at idle..you’ll see the rev or rpm bouncing up and down ..as if it needs a tune-up or spark plugs..now it could be that but usually it’s the carbon build up. It usually costs at the dealership $3-4 hundred dollars but you can also go to grease monkey or tires plus for the same thing, it usually costs $130 but they call it a different thing..forgot what it was.
I have 154,000 on 07 IS250
No Carbon problems (yet)
Advice:
1) Accumulate highway miles at high speeds for long distances
2) When warmed, flog it
3) Oil: low Noack and high PAO oils. TGMO oil is uncomfortably high Noack. Mobil 1 EP fits the bill for me
4) NO!!! Sea Foam....its made for outboard motors. You need a product w/PEA. Techtron, Red Line, Gumout. Make sure it has PEA on lable
4a) Put one bottle in when tank is below 1/4-concentrates power of cleaning
4b) Put in another bottle b4 fill up w/Top Tier gas
5) Spray CRC Intake cleaner into warmed up engine about 1x per 50K miles
6) Enjoy your ride.
Addendum: stop and go in cold temps in NOT your friend. LIMIT stop and go, get your car sufficiently warmed b4 going out into cold/stop/go traffic
Advice:
6) Enjoy your ride.
Advice:
6) Enjoy your ride.
Advice:
6) Enjoy your ride.
It is possible to do it your self. You will need a shop vac and a few other things but there was a guide either on here somewhere or I might of seen else where. If you feel you don't have the ability to do it yourself, look for a VW/BMW Shop. They more than likely have a lot of experience doing Walnut Blasting.
What exactly are you guys doing when you describe "walnut blasting"?
Basically cleaning out the intake valves with walnut media which I believe are walnut shells, so they blast the valves with a fancy shop vac and wand adapter onto the valves which dislodges the carbon off the valves and sucks it up I think
corolla05
08-30-22 05:20 PM
ellsmirip2
08-16-17 11:39 AM
