Warning light on instrument panel
09-14-18 | 07:17 AM
What does the triangular-shaped warning light on the instrument panel mean? It is the red one, not the low tire warning light. Mine has come on this morning while driving
09-14-18 | 07:27 AM
It can come on for a whole array of reasons - ranging from a due oil change to a door being open. Did you see a warning message on the center screen?
09-14-18 | 07:57 AM
The only warning message was low tire, but the low tire warning light was on as well.
09-15-18 | 06:12 AM
Then it probably just came on to tell you one of the tires was low on pressure...if not a sensor may be failing.
09-15-18 | 06:25 AM
Quote:
Originally Posted by
Viru
A faulty or depleted TPMS sensor causes "CHECK SYSTEM", not "LOW TIRE", so I'm going with your first answer.
09-15-18 | 07:41 AM
Thank you for the replies. I had a screw in tire causing low tire. After repairing, the low tire pressure and the warning light went off. I was concerned the warning light was something else. Thanks again
09-15-18 | 11:30 AM
My favorite time for the Red Triangle to blair is pushing it hard through a corner whereby "Low Washer Fluid" comes up! lol....
09-15-18 | 01:10 PM
2013FSport
This has happened to me too many times during hard cornering. Damn you washer fluid!
Jeff
09-15-18 | 08:34 PM
Jeff Lange
Jeff
I guess I haven't been cornering hard enough...
Shrink
ES - 5th Gen (2007-2012)
12-02-23 09:31 PM
Shrink
10-15-18 02:25 PM
dlap
03-07-10 06:24 AM
sidgriggs
09-21-06 08:17 AM
firstls430
03-17-06 05:21 PM
