2011 6mt traction control question
hi I have a canadian is250 with the 6mt transmission and I cannot turn off the traction control. the button press from a stop does not turn on the dash light nor does the button hold from a stop turn on the 2nd light. should these lights light up during the start up sequence? I don't see them on during that either.
my question is - could the light be out on both of these, which seems unlikely, the rest of the dash lights function
or is there something else I can check? is there an alternate way of verifying the traction control system
I used an obdii scan tool and did not see any codes.
one interesting thing are the extra menus in the touch screen, but this is a base model from canada and doesn't have the touch screen![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
thanks for the help
thanks for the help
As an owner of a 2011 base model Canadian-spec 6MT car, I feel I can speak to this.
When you press and release the button "TRAC OFF" should appear on the dash information display. If you press again it will disappear and traction control will be back on. Traction control will come back on by itself at 50 km/h.
If you press and hold for 3 seconds, the VSC off light on the tach will also illuminate and traction and stability control (VDIM) will be disabled. If you press again, it will all disappear and VDIM will be re-enabled.
VSC off should illuminate when starting the car, TRAC OFF is just a display on the LCD and so does not show during startup.
If none of that is working as it should, chances are something isn't working right (the switch, the body ECU, the ABS ECU, the engine ECU or some wiring between them).
Jeff
Jeff
Thanks Jeff, that's really helpful
the VSC light doesn't come on during start up. since the gauges are mph vs kph now, it might make sense that this light simply doesn't work - i don't know for sure but I wonder if the importing dealer switched these when it moved to seattle.
I'll read up on replacing that light.
If you have a quick shifter handy or know where i can get one, I'd be up for one of those
oh amazing - I bet it all works as expected, this car is in pretty decent shape. Think it is worth the trouble to ebay a facelift / 2010 + cluster? - if it is just traction control lighting up, i might not bother, i can press the button then press and hold it for 3 seconds with no light
if there are other features and things, maybe more interesting - the 'mode' button works and shows me the temp, miles till empty, etc
that really helps understanding what is going on - thanks again Jeff
and if this ever comes about, let me know - would probably pay a bit, the lexus part was over $400 ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
"I am working on something, but can't say much more than that.
Jeff"
Jeff"
thanks 2013FSport, i'll give it a shot- sounds like the near lsd that came with the manual isn't that amazing. worth it to go lsd 4.10 gears from the 86 or the 3.91 from the auto?
Technically it it's an eLSD as the ABS wheel speed sensors are working the electronics to limit power output and apply braking to the free spinning wheel if for example one were trying to launch and lit up the rear.
That being a 250, I'd stay w the 4.083:1.... unless you happen to get a screaming deal on the 3.9.
it has an orange triangle with an ! in the middle of it that goes away and then displays a 'check complete' message - I'll see if I can get a pic after work tonight.
Jeff
Stuno1
IS F (2008-2014)
17
09-05-14 06:57 PM
