All other windows roll up and down fine. I can even use the keyfob function and that will roll the drivers window down but it won’t roll down at the switch. Bad connection on the drivers window button or the whole control panel needs a replacement?
This used to happen to me on my driver window and my front passenger window. I would try to roll them up and about half way through they would roll back down and I was told it could be my tint, but for some reason it stopped happening. In your case with it not working at all it could possibly be a bad connection like you stated. Try taking off the door panel and seeing if there is a bad connection. There is no way it could be the entire control panel because you can still use your keyfob and it rolls down and only happens when using the switch.
