Radio Noise
Hi i have a 2006 lexus IS250 non navi head unit. I'm having a problem where the radio turns on but no sound comes out. I'm assuming there is some kind of grounding issue. I had a problem for a couple months where when it rained the radio would make a noise for the first couple minuted of turning the car on then it would be normal after that. now it doesn't give out any sound at all. What are your thoughts?
https://www.clublexus.com/forums/is-...amps-fail.html
Check the radio amplifier area for water. It's located in the trunk facing the front. Right hand side under the plastic tray.
Hey bud thanks for the reply and yes there looks like moisture is definitely in there... Are they any ways to test out the amp or should i just buy one on ebay for $200 and give it a shot??
myLexRX
08-27-20 12:35 AM
OneUnite
01-06-10 10:51 PM
imjohnphan
12-25-07 09:59 PM
