Radio controls- FM AM AUX SAT turning off
My lower control board for the audio keeps turning on and off it seems like whenever i go over a bump it will turn off and eventually turn back on after hitting another bumps or just with time...becoming quite annoying. I can hit the volume/power button and I get nothing.
There are no lights on the AM FM AUX SAT buttons. Says to me there is a power issue..meanwhile the upper monitor portion of the dash with climate/gps screen continues to work just fine and has never had issues.
Let me know what you all are thinking, thanks!
Well, i have seen a few with that problem including myself. The control **** not working properly and end up with replacing it. Your problem is a little more cause no light for AUX AM FM SAT. It could be one of diode inside not working properly. Highly recommend you to fix the control face.
There are no lights on the AM FM AUX SAT buttons. Says to me there is a power issue..meanwhile the upper monitor portion of the dash with climate/gps screen continues to work just fine and has never had issues.I have had nothing done to the car since an oil change and new brakes a few weeks ago.
The bad part is I took it the local Lexus dealer which is a HUGE dealership here in VA, they had no idea what to tell me...well except to replace the entire radio/map unit (upper and lower).
danis25000
02-21-18 04:17 PM
