Aftermarket headlights DRL light problem
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20181020_221628_47e6cee752259551120eef3df393909d738f3584.jpg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20181020_221620_dd104b9a9604bb871fc144b1522039fb821c9445.jpg)
Hi everyone, to begin with I installed some headlights on my lexus is250 06 about 8 months ago, and just a month ago the DRL light ( Nike swoosh) on the passenger side turns on whenever it wants to, I've taken the headlight out and moved a couple wires around thinking it was a wiring problem, but no luck. It is plug and play, also it comes to turn on only in the mornings when it's cold. Driver side works great as it should. Anything helps, thanks.
If it's only been 8 months, I would contact the manufacturer immediately. Most companies offer a standard 1 yr warranty and will ship you a replacement at no cost to you.
sorry for the late respond, but I've tried contacting them and they told me they don't have me on their file, from when I purchased it (bs) , so I'm basically screwed unless I figure all this out or try fixing it myself. Thanks for the suggestion tho.
Pete1980
10-08-18 07:58 AM
