New headlight option is coming soon
#256
Been reading a lot of posts with you guys having problems with the low beam/drl and wanting to disconnect it... Find someone with a techstream (or buy one on ebay for 15 bucks) and turn off your DRL. Seriously. No need for running relays etc... If anyone is in the bay area, PM me I can try to help u out.
Sorry this is going to be a silly question but which one specifically do I need? I looked on Ebay bit got a bit confused.
#257
I just bought the cable from eBay. The software they gave me didn't work so I downloaded an older version which worked great. You have to use a XP pc. Had one laying around so it all worked out.
jwhy (04-30-19)
#258
I'd like to confirm this too. For those who have the Vland headlights installed, can anybody please confirm if the headlights 'auto level' up/down when switching them on like the factory HIDs do? The Vland headlights have a up/down adjusting motor, but wouldn't pulling the AFS fuse under the dash also disable this function as from factory it uses the height sensor on the rear suspension to detect the angle of the vehicle?
Photo that tbulsara posted earlier in the thread showing the back of the headlight with the up/down motor shown:
By the way. I have not found an easy way to adjust these stupid lights we have so much crap in our engine bays that u have to remove parts to get to the screw. The passenger side is easier. U just remove your airbox and the up down screw is accessible the lateral screw is hidden by the fender so you would have to take these out to adjust those which is a pain to adjust, reinstall etc until you get it right. The left side is a little harder. More crap there. I think though removing the filler neck for the washer fluid might get you access to the screw. I just adjusted the passenger light vertically. It was way too low out the box. The drivers side is a little low too but I'm gonna see if I can live with it without crashing at night...
#259
I can confirm these do not have a motor to automatically go up and down like stock HIDs. (you actually pull the fuse (AFS) which I think also powers the auto level on the OEM HID lights to kill the AFS dummy light) those screws marked on the picture are just to adjust the lights.
Most people wont realize that the beam is off until they see the light output against a flat surface like a wall at about 25 ft away or closer.
Joelseff (04-23-19)
#260
Same here. I have to adjust my lights. Out of the box the driver's side light beam was about 1 ft. higher than the passenger side. I need to find the right sized wrench and I'll be able to adjust the vertical screw (white screw pictured) while the headlights are on the car. This is doable with just barely enough room on the passenger side with air box removed, and the driver's side the washer fluid filler neck will need to be unbolted (takes 5 seconds) and just moved to the side. From there it seems just enough room to fit a combination or ratchet wrench and adjust the light vertically.
I used an 8mm socket not attached to the ratchet and turned it by hand. It worked. Got them adjusted pretty good now.
#262
#263
I'm a newbie and I'm not sure if this has been discussed. I bought these pairs from eBay for my 2012 IS250C. Came to find out, the mounting bracket is different than the one from the OEM headlights. Do you need to buy a different brackets and if so, where can I buy them? Txs!
#264
#265
I had the dealer disable the DRL bulb since it was flickering and they were able to leave the swoosh strip on. Everything works great. Prior to them disabling the drl bulb I was just turning my headlights on and staying out of the drl mode to avoid the flicker.
Just putting that out there for anyone not looking to connect a 12v source or cannot use the techstream cable and software to disable it on their own.
#268
#269
