New headlight option is coming soon
Old 11-01-18, 05:18 AM
eykash
eykash's Avatar
Default New headlight option is coming soon
Hey guys,
What do you think about these headlights for Lexus is250 ? They will come with led projectors. Mass production will start in November. Manufacturer promises +- same price as halogen DEPO.
PS. I am not selling these headlights and i am not a manufacturer.
Mikeym718 (11-28-18)
Old 11-01-18, 05:24 AM
MikeFig82
MikeFig82's Avatar
The last output shot looks decent. I'll definitely be interested as long as it's a good quality build.
Old 11-01-18, 05:48 AM
Aspect
Aspect's Avatar
Looks good! Not a big fan of the shrouds around the projectors, kinda Acura TSX'ish. Light output looks good. I already did a led projector retrofit on mine so I'm not touching anymore lights :P
Old 11-01-18, 05:58 AM
Zynthe
Zynthe's Avatar
Will the lights work if i have OEM HID and AFS lights?
Old 11-01-18, 06:00 AM
eykash
eykash's Avatar
I don’t know. I am not manufacturer or seller of these headlight.
Old 11-01-18, 07:55 AM
metaleckz
metaleckz's Avatar
My friends and I talked to vland. They said about 450 shipped.
Old 11-01-18, 07:59 AM
Petet
Petet's Avatar
I’m definitely interested in them. If I had to guess there just like every other aftermarket head light. Might need to repin a wire , remove afs fuse and maybe have the DRL turned off.
Old 11-01-18, 11:08 AM
Gville350
Gville350's Avatar
I've already got a new set of TYC (OEM style) headlights in my attic ready for install this winter. If I had not already purchased these, this new set would definitely be on my "to watch list".
Old 11-01-18, 12:37 PM
aiexbadboy
aiexbadboy's Avatar
Curious if itll work with oem hid + afs , hopefully theyll reveal more info soon, thanks for the heads up
Old 11-01-18, 02:04 PM
porto1610
porto1610's Avatar
Default Isf
Just wondering if these would fit for a 08 ISF.
Old 11-01-18, 05:03 PM
flowrider
flowrider's Avatar
Received 1,896 Likes on 1,337 Posts
^^^^If they fit an ISX50 they will fit an ISF. However the question has been raised are they halogen only or will they retrofit the HIDs. All ISFs are HIDs.
Lou
Old 11-01-18, 07:16 PM
Zmon
Zmon's Avatar
Certainly something new and different. I'm not hopeful output is great though, probably near the halogens output, or worse probably.
Old 11-02-18, 07:08 AM
Aspect
Aspect's Avatar
so other than the cool turn signal these would actually be harder to make better via a retrofit or bulb change given the housing design then probably eh? I never looked into these new squarish projectors makers like acura are using, do they use LED bulbs or are they an integrated design I wonder?
Old 11-02-18, 10:11 AM
Zmon
Zmon's Avatar
Doubtful they can be retrofitted at all considering they're LEDs, the projector design alone pretty much nixes any other LED projector on the market. Most likely using an integrated design since two of the lights are for the low beams.
Old 11-02-18, 11:37 AM
sinister2c
sinister2c's Avatar
These will not be AFS compatible. You will probably have to pull the fuse, no matter what.
Hopefully the LED beams and output are good. Looks like TRS and Morimoto have been getting alot of these new china LED housing to the market but theirs are much better QA/QC and they have these MFGs refine and build their lights to higher specs than these. At the $450 price point, I wouldn't expect much out of these.
The look like they use the back housings from the VIPMotoZ style lights.
https://www.alibaba.com/product-deta...gA995RThhWN_BI
Quick Reply: New headlight option is coming soon
