2012 IS250 headlights HID or Halogen?
Hello all,
My wife has a 2012 IS250 and the passenger side low beam is fading to yellow and I believe needs to be replaced. Is there a way to find out if the light is the HID D4S or the halogen H11 without popping the hood? Thanks for the help.
Im sure its HID as well but if you want to make sure you can use your vin to find the specifications of your vehicle. Should be under port or factory installed equipment:
https://drivers.lexus.com/lexusdrive.../vehicle-specs
I could be wrong, but I believe that HIDs take time to warm up as compared to halogens which get bright instantly.
also, believe oem fog lights are halogen, so if low beam are halogens too they should be the same color. If they're HID, then low beam should be a lot brighter than your fog lights
