Parking Assist Front Sensors.
For those people who have parking assist on their car, how close do you have to get to an object before the front sensors go off? Is there a way to adjust the sensors to have more sensitivity in the front? I know on the nav you can adjust the rear, but nothing for the front.
I felt like I got pretty close to the car when I turned out of a parallel parking space. I purposely turned close to the car to see if the sesnor would go off like the rears do when I'm reversing, but it doesn't. The sensors work because when my girlfriend walked by when the car was in neutral, the sensor went off. Does the front only work only in certain gear positions?
Thanks
Thanks
Super Moderator
I find the front sensors to be nearly worthless. They go off when someone walks in front of the car, and sometimes they alert (falsely) when it is snowing heavily or when the bumper is caked with snow and ice, but they rarely go off when backing into a tight parking space. Also be aware that they are only at front corners, so do not attempt to use them to judge distance when pulling forward.
Thanks
Thanks
AlohaCab
CT 200h Model (2011-2017)
08-29-15 11:44 AM
