Balance of the RWD IS350
That time of year again in PA with the IS350 sucking in that dense 20* air and begging to be driven with traction control off. The Car really takes on a new personality on the salted cold roads. The sound of the engine whine mixed with the throaty burble of the Injen intake on the cold mornings is really such a treat. Launching from a red light the tach just climbs with ease with the mix of traction and wheel spin that will having you riding that bull until you let off the gas. Car feels so much more nimble on the cold roads and can be throttle steered out of corners with the precision of some of the best German cars out there. On warm dry roads the IS350 will always push through the turns and really takes a lot to break the rear end loose but on these cold late autumn mornings will have you flicking the car all over the place. Push slides, power slides, roll the gas, counter steer and check to make sure no one is looking and off to work you go. Days like this make me thankful cars like the RWD IS350 still exists!
OG Member
Nice write-up. As newer generations of vehicles continue to get heavier, a longer wheelbase, etc., I too am thankful that the 2IS sport sedan has a respectable weight distribution (52:48), curb weight (3,527 lbs), wheelbase (107.5 in), a potent dual-injector high-compression N/A V6 (with 90% of its peak torque available at 2,000 RPMs), and an aggressive final drive ratio (4.08).
For a V6 luxury sedan, it continues to be a fun sleeper car and is why I've kept mine for over a decade.
Gotta admit I love this car! It's so fun getting the hole shot on other players! I'm certain it would be more playful with a proper LSD! That said Black Friday only dropped $150 off the OS Giken LSD, so I didn't do it. It is going to happen tho!
@redspencer how is yours setup? Is it 1.5?
How many of you have weighed them? She's a bit tubby weighing in at 3,950#... but the split does reflect the 52/48.
And for being a sleeper, I just love stopping at a red light with a Honda next to me, potato shooting tail pipe and big wing. I usually let them get the jump so I can pass them laughing.
The previous owner of my car put on Michelin Pilot sports on the front but a/s 3’s on the rear. My car has always been tail happy, and I love it. Then I added the rear bar. The brake dust is often more present on the rear wheels. Wish I got a little more freedom before the traction steps in, especially when the road isn’t level. But I still have fun.
Best compensation is done while turning left so body roll applies more pressure to the right rear giving near equal bite so nannie master doesn't step in for dose of killjoy!
And to your point; mine came mismatched too with some near bald Nitto's on the rear and it spun those up pretty easy. Likely why the RR brake pads were done well ahead of the left.
I’m not sure what you mean. An open diff will always flow torque to the wheel with the least grip. Turning left or right wouldn’t matter.
My complaint about the T/C extends to the stability control too. This one corner I try to take spiritedly has about a 8-10 foot rise then flattens, but when I mash the throttle mid corner, even with grip, the stability control says nope. Sure I can turn it off, but the car has to be stopped for that and I don’t always remember to.
OG Member
I do remember years back when @Gville350 ended up buying a JDM OS Giken LSD which ended being a 2-way differential that was previously used by a Formula D team!
https://www.clublexus.com/forums/per...pic-heavy.html
2013FSport (12-05-18)
Engine torque twists the chassis planting the left, lifting the right rear. Pin an open diff rwd car on flat land and more often than not, the right side goes up in smoke.
If you take off turning left like pulling out to turn with throttle applied the body rolls to the right applying more pressure to the right while also lifting the left creating near equal loading of both tires and you get cheap thrills!
Try it some time!
And ya, exact opposite turning right. Here the right is UNloaded and totally spins up.
