I recently got in an accident and had all body work fixed and now all those lights are on currently.I know the shop should have fixed but my insurance is putting up a fight saying "coincidental cause" those lights turned on due to curb rash on all wheels. I just replaced the front right wheel bearing as it was cheaper to buy that than the speed senor itself. I couldnt find any info online or manuals showing any vital electronics which would cause problems if damaged or faulty, so I come here for help.
So I scanned it and a C0200 came up. I replaced the hub which included the abs sensor, and im having trouble finding the wire harness on any auto parts store
tl;dr: The OP ordered a hub that he thought was for the correct side as apparently the sensors are directional, ended up it was for the other side and he ordered the correct one through Lexus instead. Something to consider for you if you're sure no wiring was damaged.
Is there any specific part #'s online for the abs harness? I will verify the bearing for the right side tomorrow but I have no idea to tell if a cable got broken in the crash.
Seeing that picture makes it hard for me to believe any wiring harness for the ABS could be affected. More than likely it was probably the wrong bearing.
I double checked to make sure it was the right side for the car.
