Please help!!!!! [CEL and noise after tuneup]
So I hope that I'm posting this in the right place.. I have used this website to find answers to many of my issues in the past and now I have finally made an account and decided to ask for advice on this. I have a 2012 Lexus IS250. I asked my husband to replace the brakes and he decided to give the car a tune up and do some maintenance. While changing the cabin air filter, he broke the actuator and we are waiting to see if the glue will hold as a fix (got the idea here). Last night he changed the spark plugs and cleaned the throttle body. Today when he started it up, the check engine light came on and this truly scary and weird sound is coming from the intake area. It is VERY loud and continuous whether or not you step on the gas. We didn't attempt to move it but he did step on the gas and the sound just gets louder. ANY ideas?! I love my Lexus so much.. I'm heartbroken right now..
I have a 20 second video but no clue how to upload it.
Would be interested in the video to hear what the noise is. I would not start the car and have him pull one of the spark plugs and verify they are the correct length. Could be a few things but normally start with the simplest first like checking for forgotten tool or a connector that wasn't plugged back in.
You can upload the video to here for free then post the link. http://sendvid.com/
Thank you for the link!!! So cool!
Here's my video clip of the horrible sound..
http://sendvid.com/glvn8e3n
NOTHING after market on my car.. Yes, it really sounds like it's coming from the throttle body and my husband said he didn't see the flap moving when the gas pedal was pressed last night. There was absolutely NOTHING wrong with the car..just needed rear brakes..
I would check to see if the molex plugs that connect to the coil packs. Cylinder 3 and 5 and the ones directly under the intake. I would also pull the Mass airflow sensor that sits on top the intake tube. Unplug and replug it back in. Could be dirty or just not hooked up. I would bet money that the connectors need reseated. Also, Did he set the gap on the spark plugs?
This is the cylinder to numbers to help identify the location. I'd check the connections again as suggested. Make sure you hear the connector click in. What type of cleaner did you use? Did you get that cleaner on the MAF as well? I know that MAF ususally has a specific cleaner for it.
Parts cleaner on the MAF might have killed it. That's a $100ish part at AutoZone if its indeed dead.
Folks cleaning the throttle body tend to be too forceful on the butterfly and might cause the plastic gears within the TB assembly to break and cause the butterfly plate no longer to function. But of course, double-check the connector to the TB first!
I'm still waiting for him to get home from work to recheck his steps but he thinks that it's the butterfly like the last person suggested. I'll update when I know and I truly appreciate everyone's responses!!
That might explain that crazy noise from the throttle body area. Will be following this post to see what the fix turns out to be.
