2007 TPMS light coming on
The TPMS light came on after a highway run of about 45 minutes, but it came on after coming to a stop and idling for a few minutes. This happened 3 times. Since the sensors were old, I had them all changed, and it’s still happening.
HELP!!!
HELP!!!
TPMS coming on means the air pressures are low. Before we can comment on your situation, we need to get a little bit more information.
Who replaced your TPMS? Did they evaluate and determine they needed replacement? Normally the batteries die and hence need replacement or otherwise some die because they were
Super Moderator
Actually, TPMS light coming on does not necessarily mean pressures are low. TPMS light with the message "LOW TIRE" in the center display means pressure is low in on or more wheels, but TPMS light with "CHECK SYSTEM" means that the car isn't communicating with one or more sensors, often because TPMS sensor batteries have failed. The OP didn't mention whether he is seeing "LOW TIRE" or "CHECK SYSTEM"
Super Moderator
I'd bring it to a tire shop that has a dedicated TPMS tool (BARTEC or similar), preferably when the CHECK SYSTEM is on. With a TPMS tool, they can individually scan each wheel, so you'll know which sensor is bad. And if none are bad, they can use the tool to re-program the sensor ID numbers into the car.
Ltaboso
IS F (2008-2014)
19
03-19-15 09:16 AM
