Buying 07 IS250 76k Miles Good?
Hey guys so I just wrecked my Navigator the other week looking to get something small preferably a Lexus. found this Lexus at a BMW dealership for $10k I would have to finance so private party is out of the picture and for the price it's the lowest miles and the only one that's one owner car has all history maintenance only thing that concerns me is I've herd of these cars having the gooey dash board and this one hasnt been done. Another thing is last maintenance done at Lexus was at around 65k miles in 2016 it's about 2 years later and car was only driven 10k miles since then. Not sure if that's a bad or a good thing. Also Carfax has no accident history but on Lexus it shows it was at there collision centre maybe something small?
Tell me what you think and what should I look for when buying. Water pump has been done which is good. Going through some maintenance history on them seems like the water pump is a weak point?12/06/2016
12/03/2016
Repair# 241236C
Reported By: Lexus of Cerritos
Service:
Description: TIRE INFLATION SERVICE COMPLETED AND TIRE PRESSURES ARE AS FOLLOW; ___ PSI LF,___ PSI RF, ___ PSITHANK YOU FOR JOINING US IN THE FIGHT AGAINST CANCER. WE'VE PARTNERED WITH THE BCRF TO RAISE FUND ~|~THANK YOU FOR JOINING US IN THE FIGHT AGAINST CANCER. WE'VE PARTNERED WITH THE BCRF TO RAISE FUNDS FOR THE WORLD'S MOST PROMISING RESEARCH TO ERADICATE BREAST CANCER. 100% OF YOUR DONATION GOES TO BCRF. PLEASE VISIT DRIVEPINK.COM FOR MORE INFO. ~|~THANK YOU FOR JOINING US IN THE FIGHT AGAINST CANCER. WE'VE PARTNERED WITH THE BCRF TO RAISE FUND
Service: ABSORBER, SHOCK/STRUT (REAR) - REPLACE
Description: ABSORBER, SHOCK/STRUT (REAR) - REPLACE ~|~ABSORBER, SHOCK/STRUT (REAR) - REPLACE ~|~ ~|~67489 400 REPLACED BOTH REAR STRUTS, NOW OK.
Service: BATTERY GREEN, CHECKED AND OK AT THIS TIME
Description:
Service: BRAKES GREEN, SEE YOUR SERVICE CONSULTANT ON YOUR NEXT VISIT
Description:
Service: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT
Description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~|~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~|~ ~|~67489 PERFORMED INSPECTION.
Service: ELEMENT, AIR CLEANER - REPLACE
Description: ELEMENT, AIR CLEANER - REPLACE ~|~ELEMENT, AIR CLEANER - REPLACE ~|~ ~|~67489 30 REPLACED ENGINE AIR FILTER.
Service: INSPECT BRAKE PADS AND/OR LININGS, ROTORS AND/OR DRUMS
Description:
Service: MICROFILTER - REPLACE
Description: MICROFILTER - REPLACE ~|~MICROFILTER - REPLACE ~|~ ~|~67489 50 REPLACED CABIN AIR FILTER.
Service: MOUNT AND BALANCE TWO TIRES
Description: MOUNT AND BALANCE TWO TIRES ~|~MOUNT AND BALANCE TWO REAR TIRES ~|~ ~|~67489 100 REPLACED AND BALANCED 2 TIRES, DOT#'S DEL2416, DEL2416
Service: PADS, BRAKE (FRONT) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE
Description: PADS, BRAKE (FRONT) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE ~|~GUEST STATES FRONT BRAKES ARE NOISY. CHECK AND ADVISE ~|~ ~|~67489 200 VEHICLE NEEDS FRONT BRAKE PADS AND ROTORS, ALSO NEEDS REAR BRAKE PADS AND MACHINE ROTORS. FRONTS LOW AT 1MM REAR LOW AT 2MM. PERFORMED FRONT BRAKE SERVICE WITH ROTORS, NOW 11MM
Service: PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE
Description: PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE ~|~PADS, BRAKE (REAR) - REPLACE AND RESURFACE ROTORS OFF-VEHICLE ~|~ ~|~67489 200 PERFORMED REAR BRAKE SERVICE, NOW 11MM
Service: PERFORM 4 WHEEL ALIGNMENT
Description: PERFORM 4 WHEEL ALIGNMENT ~|~PERFORM 4 WHEEL ALIGNMENT ~|~ ~|~67489 150 PERFORMED ALIGNMENT, PRINT OUT ATTACHED.
Service: PUMP, COOLANT - REPLACE
Description: PUMP, COOLANT - REPLACE ~|~PUMP, COOLANT - REPLACE ~|~ ~|~67489 400 REPLACED WATER PUMP DUE TO EXCESSIVE BEARING PLAY AND SEEPING COOLANT.
Service: REPLACE ENGINE OIL
Description:
Service: REPLACE ENGINE OIL FILTER
Description:
Service: RESET SERVICE INDICATOR
Description:
Service: ROAD TEST
Description:
Service: SERVICE - 65,000 MILES
Description: SERVICE - 65,000 MILES ~|~SERVICE - 65,000 MILES ~|~ ~|~67489 50 PERFORMED 65,000 MILE SERVICE. FRONT AND REAR BRAKES NEW TODAY FT TIRES 6/32 REAR NEW
Service: TIRE - REPAIR
Description: TIRE - REPAIR ~|~GUEST STATES TIRE PRESSURE LIGHT IS ON.CHECK AND ADVISE ~|~ ~|~67489 FOUND ALL TIRES LOW, SET TO SPEC, NOW OK. VEHICLE NEEDS REAR TIRES.
Service: TIRES GREEN, PLEASE SEE YOUR SERVICE CONSULTANT AT YOUR NEXT VISIT
Description:
Repair# 0126497
Service:
Description: MOVED TO: 126497C LINE: B ~|~MOVED TO: 126497C LINE: BMOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: B MOVED TO: 126497C LINE: BMOVED TO: 126497C LINE: C ~|~MOVED TO: 126497C LINE: CMOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C MOVED TO: 126497C LINE: C
Service: MOVED TO: 126497C LINE: A
Description: MOVED TO: 126497C LINE: A ~|~MOVED TO: 126497C LINE: A
Service: MOVED TO: 126497C LINE: D
Description: MOVED TO: 126497C LINE: D ~|~MOVED TO: 126497C LINE: D
Service: MOVED TO: 126497C LINE: E
Description: MOVED TO: 126497C LINE: E ~|~MOVED TO: 126497C LINE: E
Service: R&R BANK 1 & BANK 2 INTAKE CAMSHAFT GEAR ASSY
Description: R&R BANK 1 & BANK 2 INTAKE CAMSHAFT GEAR ASSY ~|~MISCELLANEOUS ENGINE MECHANICAL - LOUD KNOCKING SOUND CAN BE HEARD RIGHT AFTER INITIAL START ESPECIALLY COD START. PERFORM DIAGNOSIS ~|~FOUND CAM GEARS FAILURE ~|~50191 FOUND CAM GEARS FAILURE EG7027 T1.06 T2.04 600 REMOVED AND REPLACE BANK 1 AND BANK 2 CAM GEARS AS PER ONE TIME GOODWILL. NOW MORE NOISE AT THIS TIME
Service: REMOVE SERRATION PATTERN & INSTALL NEW WIPER ARM NUTS
Description: REMOVE SERRATION PATTERN & INSTALL NEW WIPER ARM NUTS ~|~SAFETY RECALL DLA - REMEDY NOTICE - 2006 THROUGH EARLY 2012 MODEL YEAR IS 250 AND IS 350 2010 THROUGH EARLY 2012 MODEL YEAR IS250C AND IS 350C AND 2008 THROUGH 2011 MODEL YEAR IS-F FRONT WIPER ARM NUT. ~|~AS PER SSC DLA ~|~50191 3524AA 60 PERFORMED DLA CAMPAIGN
Service: REPLACE INTERNAL TRUNK RELEASE LEVER
Description: REPLACE INTERNAL TRUNK RELEASE LEVER ~|~PRODUCT UPDATE DLB - REMEDY NOTICE - CERTAIN 2006 TO EARLY 2013 MY IS 250 IS 350 & IS-F CERTAIN 2007 TO EARLY 2013 MY ES 350 & ES 300H & CERTAIN 2013 MY GS 350 & GS 450H VEHICLES - INTERNAL TRUNK RELEASE LEVER (HANDLE). ~|~AS PER SSC DLB ~|~50191 3611AA 30 PERFORMED DLB CAMPAIGN
Repair# 126497C
Service:
Description: WORN FRONT TIRES - NOT SAFE TO DRIVE RECOMMEND REPLACE BOTH FRONT TIRES AND WHEEL ALIGNMENTBRAKES GREEN, SEE YOUR SERVICE CONSULTANT ON YOUR NEXT VISIT REAR BRAKES MARGINAL
Service: BATTERY CONDITION MARGINAL - YELLOW
Description:
Service: DETAIL - 42
Description: DETAIL - 42 ~|~INTERIOR AND EXTERIOR DETAIL
Service: FLUID, DIFFERENTIAL (REAR) - REPLACE
Description: FLUID, DIFFERENTIAL (REAR) - REPLACE ~|~FLUID, DIFFERENTIAL (REAR) - REPLACE ~|~ ~|~50191 REPLACED REAR DIFFERENTIAL FLUID COMPLETE
Service: INSPECT BODY PAINT AND CORROSION
Description:
Service: INSPECT BRAKE LINES, HOSES AND CONNECTIONS
Description:
Description:
Service: INSPECT DRIVE AXLE BOOTS
Description:
Service: INSPECT DRIVE BELT(S)
Description:
Service: INSPECT ENGINE COOLANT LEVEL
Description:
Service: INSPECT EXHAUST SYSTEM AND HEAT SHIELDS
Description:
Service: INSPECT FUEL TANK, CAP, LINE AND HOSES
Description:
Service: INSPECT RACK AND PINION ASSEMBLY
Description:
Service: INSPECT REAR DIFFERENTIAL FLUID LEVEL
Description:
Service: INSPECT STEERING OPERATION AND LINKAGE
Description:
Service: INSPECT SUSPENSION BALL JOINTS
Description:
Service: INSPECT TRANSMISSION FOR LEAKS
Description:
Service: MEASURE BRAKE PAD THICKNESS
Description:
Service: ONE DAY LOANER
Description: ONE DAY LOANER ~|~COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED WITH US.
Service: RECOMMENDED SERVICE - E.F.I. SERVICE
Description:
Service: REPLACE AIR CLEANER FILTER
Description:
Description:
Description:
Service: REPLACE SPARK PLUGS
Description:
Description:
Service: ROAD TEST
Description:
Service: SERVICE - 60,000 MILES
Description: SERVICE - 60,000 MILES ~|~SERVICE - 60,000 MILES AS PER GUEST REQUEST INCLUDE TUNE ~|~ ~|~50191 680 PERFORMED 60,000 MILE SERVICE WITH SPARK PLUGSFRONT BRAKE AT 8.0MM REAR AT 4.0MM TIRE CONDITION FRONT AT 4/32 WORN INNER EDGE NOT SAFE TO DRIVE REAR AT 6/32RECOMMEND TO REPLACE TWO FRONT TIRE, ALIGNMENT AND EFI SERVICE
Service: TECHNICIAN'S MULTI POINT INSPECTION IS EITHER NOT NEEDED AT THIS TIME, OR WILL B
Description: TECHNICIAN'S MULTI POINT INSPECTION IS EITHER NOT NEEDED AT THIS TIME, OR WILL B ~|~TECHNICIAN'S MULTI POINT INSPECTION IS EITHER NOT NEEDED AT THIS TIME, OR WILL BE PERFORMED AS PART OF MAINTENANCE SERVICE
Service: TIRE INFLATION SERVICE COMPLETED AND TIRE PRESSURES ARE AS FOLLOW; ___ PSI LF,__
Description:
Repair# 0099827
Service: AIR COND & HEATER - 25
Description: AIR COND & HEATER - 25 ~|~GUEST STATES AC IS NOT BLOWING COLD AIR.CHECK AND ADVISE ~|~FOUND HIGH SIDE AIR COND PRESSURE TUB WAS LEAKING ~|~46666 FOUND HIGH SIDE AIR COND PRESSURE TUB WAS LEAKING REPLACED HIGH SIDE PRESSURE TUB ,EVACUATE AND PERFORMED RECHARGE COMPLETE NOW AIR CONDITIONING IS WORKING NORMAL- PAID FOR BY GREG'S COLLISON CENTER
Service: COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED
Description: COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED ~|~COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED WITH US.
Description:
Description:
Repair# 0093131
Description:
Description:
Service: CLEAN CABIN AIR FILTER
Description:
Description: ELEMENT, AIR CLEANER - REPLACE ~|~ELEMENT, AIR CLEANER - REPLACE ~|~ ~|~45250 REPLACED ENGINE AIR FILTER
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description: MICROFILTER - REPLACE ~|~MICROFILTER - REPLACE ~|~ ~|~45250 REPLACED AC FILTER
Service: MISCELLANEOUS ENGINE MECHANICAL - REPAIR
Description: MISCELLANEOUS ENGINE MECHANICAL - REPAIR ~|~GUEST STATES KNOCKING NOISE WHILE DRIVING.CHECK AND ADVISE ~|~ ~|~45244 TESTDROVE VEHICLE TOTAL OF 5 MILES.UNABLE TO VERIFY KNOCKING NOISE.RECOMMEND TESTDRIVING WITH GUEST.
Service: RECOMMENDED MAINT - 00 RECOMMENDED MAINT - 00
Description:
Description:
Description:
Description:
Service: ROAD TEST
Description:
Service: SERVICE - 45,000 MILES
Description: SERVICE - 45,000 MILES ~|~SERVICE - 45,000 MILES ~|~ ~|~45244 PERFORMED 45,000 MILE MAINTENANCE SERVICE.FRONT BRAKES 8MM REAR BRAKES 6MM FRONT TIRES 6/32ND REAR TIRES 8/32ND
Description:
Description:
Repair# 0071947
Description: RECOMMENDED MAINT - 00 ~|~GUEST STATES SINCE VEHICLE WAS REPAIRED AFTER COLLISON AT GREG'S AUTOBODY THERE IS A KNOCKING NOISE AT START UP WHEN VEHICLE IS COLD AND ALSO WHEN ACCELERATING.CK AND ADVISE ~|~ ~|~42192 INSPECTED REPLACED PARTS.FOUND OK.STARTED VEHICLE AT COLD START ON 6-8-11 AT 5PM.TESTDROVE 2 MILES.FOUND OK.ALSO STARTED 6-9-11 AT 8AM TESTDROVE 8 MILES.NO ABNORMAL KNOCKING NOISE HEARD FROM ENGINE.VEHICLE OK AT THIS TIME.ALSO REMOVED ALL ENGINE COV
Description:
Description:
Repair# 067844C
Service: MY NAME IS SONIA MENDOZA AND I WILL BE ASSISTING YOU TODAY. PLEASE FEEL FREE TO
Description: MY NAME IS SONIA MENDOZA AND I WILL BE ASSISTING YOU TODAY. PLEASE FEEL FREE TO ~|~MY NAME IS SONIA MENDOZA AND I WILL BE ASSISTING YOU TODAY. PLEASE FEEL FREE TO CONTACT ME IN MY OFFICE 562-865-7447 EXT 1033, OR ON MY CELL 562-480-1937, OR EMAIL MENDOZAS@AUTONATION.COM FOR ANYTHING INCLUDING MAKING SERVICE APPOINTMENTS.
Service: PROGRAMMED ECU TO VEHICLE COMPLETE ALL LIGHT CLEARED COMPTER RESET
Description: PROGRAMMED ECU TO VEHICLE COMPLETE ALL LIGHT CLEARED COMPTER RESET ~|~REPGROGRAM ECU ~|~ ~|~41203 REPROGRAMED ECU AND DOWN LOADED VIN TO ECU
Description:
Repair# 0067844
Service: MOVED TO: 67844C LINE: A MOVED TO: 67844C LINE: A
Description: MOVED TO: 67844C LINE: A ~|~MOVED TO: 67844C LINE: A
Service: MOVED TO: 67844C LINE: B
Description: MOVED TO: 67844C LINE: B ~|~MOVED TO: 67844C LINE: B
Service: MOVED TO: 67844C LINE: C
Description: MOVED TO: 67844C LINE: C ~|~MOVED TO: 67844C LINE: C
Service: PERFORMED BLA UPDATE
Description: PERFORMED BLA UPDATE ~|~PERFORM BLA UPDATE ~|~. ~|~41203 RECALL RETORQUED FUEL PRESSURE SENSOR OP#1523A1/1.7
Repair# 0060979
Service: 4 WHEEL ALIGNMENT
Description: 4 WHEEL ALIGNMENT ~|~4 WHEEL ALIGNMENT ~|~ ~|~40510 PERFORMED 4 WHEEL ALIGNMENT
Service: 40000 MILE SERVICE - 00
Description: 40000 MILE SERVICE - 00 ~|~40000 MILE SERVICE - 00 ~|~MAINTENANCE INTERVAL ~|~40510 PERFORMED 40K. FT PADS AT NEW, RR AT 4MM. FT TIRES AT 7/32, RR NEW
Description:
Description:
Description: DETAIL - 42 ~|~INTERIOR/EXTERIOR DETAIL
Service: ENGINE - 08
Description: ENGINE - 08 ~|~GUEST STATES VEHICLE SHAKES AT IDLE.CK AND ADVISE ~|~ ~|~40510 ROAD TESTED VEHUICLE. COULD NOT DUPLICATE SHAKING AT IDLE. POSSIBLY DUE TO WIRE DAMAGE. ROAD TESTED AFTER REPAIRS. STILL NO SHAKING. OK AT THIS TIME
Service: FRONT BRAKE SERVICE ; RESURFACE DISC ROTORS, INSTALL NEW BRAKE PADS AND INSPECT
Description: FRONT BRAKE SERVICE ; RESURFACE DISC ROTORS, INSTALL NEW BRAKE PADS AND INSPECT ~|~REPLACE FRONT BRAKES AND ROTORS ~|~ ~|~40510 REPLACED FRONT BRAKE PADS AND ROTORS
Service: GUEST STATES THE CHECK ENGINE LIGHT IS ON.
Description: GUEST STATES THE CHECK ENGINE LIGHT IS ON. ~|~GUEST STATES ABS AND VSC LIGHTS ARE ON.CK AND ADVISE ~|~. ~|~40510 VERIFIED LIGHTS ON. READ DTCS. RETRIEVED MULTIPLE DTCS. COULD NOT CLEAR ANY DTCS FROM SYSTEM. INSPECTED. FOUND, MULTIPLE WIRES DAMAGED FROM RODENT. WIRES DAMAGED AT FIREWALL JUNCTION UNDER BATTERY. REPLACED WIRING HARNESS.COVERED BY AAA INSURANCE.CL
Description: RECOMMENDED MAINT - 00 ~|~ ~|~ ~|~40510
Service: REPLACE 2 TIRES
Description: REPLACE 2 TIRES ~|~GUEST STATES DRIVERS REAR TIRE IS LOOSING AIR.CK AND ADVISE ~|~ ~|~40510 REAR TIRE NOT REPAIRABLE. REPLACED REAR TIRES
Description:
Description:
Repair# 0040932
Service:
Description: MOVED TO: 40932C LINE: C ~|~MOVED TO: 40932C LINE: CMOVED TO: 40932C LINE: C MOVED TO: 40932C LINE: C MOVED TO: 40932C LINE: C MOVED TO: 40932C LINE: C MOVED TO: 40932C LINE: C
Service: 9LG CAMPAIGN
Description: 9LG CAMPAIGN ~|~PERFORM SERVICE CAMPAIGN 9LG--POTENTIAL FLOOR MAT INTERFERENCE WITH ACCELERATOR PEDAL ~|~. ~|~35792 PERFORMED SERVICE CAMPAIGN 9LG-9915M5 T1-SC T2-SC
Description: COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED ~|~COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED WHILE YOUR VEHICLE IS BEING SERVICED WITH US. ~|~ ~|~35792 COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED
Service: MOVED TO: 40932C LINE: A
Description: MOVED TO: 40932C LINE: A ~|~MOVED TO: 40932C LINE: A
Service: MOVED TO: 40932C LINE: B
Description: MOVED TO: 40932C LINE: B ~|~MOVED TO: 40932C LINE: B
Repair# 040932C
Service: 35000 MILE SERVICE - 00
Description: 35000 MILE SERVICE - 00 ~|~35000 MILE SERVICE - 00 ~|~MAINTENANCE INTERVAL ~|~35792 35000 MILE SERVICE BRAKES F6MM R7MM TIRES F9/32 RR2/32 LR3/32
Description:
Description:
Description: CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~|~CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED THIS VISIT ~|~ ~|~35792 CUSTOMER REQUESTED TO HAVE MULTI POINT INSPECTION PERFORMED
Description: DETAIL - 42 ~|~DETAIL - 42 ~|~ ~|~35792 DETAIL
Service: RECOMMENDED SERVICE - TIRE REPLACEMENT
Description:
Service: TIRE(S) REQUIRE REPLACEMENT AT THIS TIME
Description:
Repair# 0017660
Service: 30,000 MILE MAINTENANCE SERVICE
Description: 30,000 MILE MAINTENANCE SERVICE ~|~30,000 MILE MAINTENANCE SERVICE ~|~MAINTENANCE INTERVAL ~|~30619 COMPLETED 30,000 MILE MAINTENANCE SERVICE.CHANGED OIL AND FILTER,AIR AND AIR CONDITIONING FILTERS,PERFORMED BRAKE FLUSH,ADDED BRAKE CLEANER AND ENGINE AND FUEL CONDITIONER,BALANCED FRONT TIRES.FRONT BRAKES 4MM REAR BRAKES 8MM FRONT TIRES 9/32ND REAR
Service: COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECH
Description: COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECH ~|~COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECHNICIANS. ~|~ ~|~30619 COMPLETED COMPLIMENTARY MULTI-POINT INSPECTION FRONT BRAKES 4MM REMAINING REAR BRAKES 8MM REMAINING FRONT TIRES 9/32, REAR TIRES 4/32 REPLACED 3 SMART KEY BATTERIES
Description: DETAIL - 42 ~|~DETAIL - 42 ~|~ ~|~30619 PERFORMED INTERIOR/EXTERIOR DETAIL
Repair# 0006431
Service: 25000 MILE SERVICE - 00
Description: 25000 MILE SERVICE - 00 ~|~25000 MILE SERVICE - 00 ~|~MAINTENANCE INTERVAL ~|~23398 COMPLETED 25000 MILE SERVICE.CHANGED OIL AND FILTER,ADDED BRAKE CLEANER AND ENGINE AND FUEL CONDITIONER,ADJUSTED FLUIDS AND TIRE PRESSURES.FRONT BRAKES 7MM AND REAR BRAKES 8MM.TIRES L/F 7/32ND R/F 10/32ND L/R 5/32NND R/R 5/32ND
Description: COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECH ~|~COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECHNICIANS. ~|~ ~|~23398 COMPLETED MULTI-POINT INSPECTION FRONT BRAKES 7MM REMAINING REAR BRAKES 8MM REMAINING LF 10/32, RF 10/32, LR 5/32, RR 5/32
Service: PERFORM SERVICE CAMPAIGN 9LA--REPLACE FUEL DELIVERY PIPE
Description: PERFORM SERVICE CAMPAIGN 9LA--REPLACE FUEL DELIVERY PIPE ~|~PERFORM SERVICE CAMPAIGN 9LA--REPLACE FUEL DELIVERY PIPE ~|~. ~|~23398 PERFORMED 9LA CAMPAIGN OP#8506FJ T1-SC T2-SC
Description: RECOMMENDED MAINT - 00 ~|~VEHICLE BROUGHT OVER FROM LEXUS OF CERRITOS COLLISON CENTER
Repair# 0212711
Service: 20000 MILE SERVICE - 00
Description: 20000 MILE SERVICE - 00 ~|~20000 MILE SERVICE - 00 ~|~MAINTENANCE INTERVAL ~|~20814 PERFORMED 20,000 MILE MAINTENANCE SERVICE.CHANGED OIL AND FILTER,ADDED BRAKE CLEANER AND ENGINE AND FUEL CONDITIONER,ADJUSTED FLUIDS AND TIRE PRESSURES.RESET MAINTENANCE LIGHT.FRONT AND REAR BRAKES 6MM FRONT TIRES 7/32ND REAR TIRES 6/32ND
Description: COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECH ~|~COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECHNICIANS. ~|~ ~|~20814 PERFORMED MULTI POINT VEHICLE INSPECTION
Description: DETAIL - 42 ~|~DETAIL - 42 ~|~ ~|~20814 PERFORMED INTERIOR/EXTERIOR DETAIL
Repair# 0200931
Description: COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECH ~|~COMPLIMENTARY MULTI-POINT INSPECTION PERFORMED BY OUR LEXUS FACTORY TRAINED TECHNICIANS. ~|~ ~|~15363 PERFORMED MULTI POINT INSPECTION
Service: MOVED TO: 200931C LINE: A
Description: MOVED TO: 200931C LINE: A ~|~MOVED TO: 200931C LINE: A
Service: MOVED TO: 200931C LINE: B
Description: MOVED TO: 200931C LINE: B ~|~MOVED TO: 200931C LINE: B
Repair# 200931C
Service: 15000 MILE SERVICE - 00
Description: 15000 MILE SERVICE - 00 ~|~15000 MILE SERVICE - 00 ~|~MAINTENANCE INTERVAL ~|~15363 MAINTENANCE INTERVAL PERFORMED 15,000 MILE SERVICE.CHANGED OIL AND FILTER,AIR AND AIR CONDITIONING FILTERS,ADDED BRAKE CLEANER,ENGINE AND FUEL CONDITIONER,ADJUSTED FLUIDS AND SET TIRE PRESSURES TO 36PSI.FRONT AND REAR BRAKES ARE AT 8MM FRONT TIRES A
Description: DETAIL - 42 ~|~DETAIL - 42 ~|~ ~|~15363 PERFORMED INTERIOR/EXTERIOR DETAIL
Repair# 0189053
Service: 10000 MILE SERVICE - 00
Description: 10000 MILE SERVICE - 00 ~|~10000 MILE SERVICE - 00 ~|~ ~|~10286 PERFORMED 10,000 MILE MAINTENANCE SERVICE FRONT BRAKES 8MM REAR BRAKES 7MM FRONT TIRES 8/32ND REAR TIRES 7/32ND
Description: DETAIL - 42 ~|~DETAIL - 42 ~|~ ~|~10286 PERFORMED INTERIOR/EXTERIOR DETAIL
Service: LOANER DISCLAIMER - 50
Description: LOANER DISCLAIMER - 50 ~|~LOANER DISCLAIMER - 50
Service: MULTI POINTS VEHICLE INSPECTION
Description: MULTI POINTS VEHICLE INSPECTION ~|~MULTI POINTS VEHICLE INSPECTION ~|~ ~|~10286 PERFORMED MULTI POINTS VEHICLE INSPECTION
Repair# 0182418
Description: ENGINE - 08 ~|~REPLACE ENGINE FILTER IF NECESSARY ~|~ ~|~7483 REPLACED AIR FILTER
Service: TIRE PRESSURE LIGHT IS ON
Description: TIRE PRESSURE LIGHT IS ON ~|~TIRE PRESSURE LIGHT IS ON ~|~ ~|~7483 REPAIRED DRIVERS REAR TIRE WITH TIRE PLUG AND RESET TIRE LIGHT
Repair# 0174956
Service: 5,000 MILE SERVICE
Description: 5,000 MILE SERVICE ~|~5,000 MILE SERVICE ~|~. ~|~5304 PERFORMED 5000 MILE SERVICE FRONT AND REAR BRAKES ARE AT 10 MM ALL FOUR TIRES ARE AT 9/32
Service: LEXUS PERSONALIZED SETTINGS
Description: LEXUS PERSONALIZED SETTINGS ~|~LEXUS PERSONALIZED SETTINGS ~|~. ~|~5304 PERFORMED PERSONALIZED SETTINGS
Service: MOVED TO: 174956C LINE: A
Description: MOVED TO: 174956C LINE: A ~|~MOVED TO: 174956C LINE: A
Service: MOVED TO: 174956C LINE: B
Description: MOVED TO: 174956C LINE: B ~|~MOVED TO: 174956C LINE: B
Repair# 0163960
Service: ACCESSORIES - 29
Description: ACCESSORIES - 29 ~|~PROGRAM MASTERKEY ~|~ ~|~COMPLETED
Description: RECOMMENDED MAINT - 00 ~|~NO WASH
Repair# 0161730
Service: CHASSIS ELECTRICAL - 21
Description: CHASSIS ELECTRICAL - 21 ~|~GUEST STATES FRONT PASS WINDOW DOES NOT ROLL UP/DOWN FROM MAIN SWITCH PLS CHK AND ADVISE ~|~ ~|~REINITIALIZED WINDOWS
Repair# 0156286
Service: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
Description: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PERFORM PRE-DELIVERY INSPECTION ~|~. ~|~3 PERFORMED PDI SERVICE AN#6898783 SAT# RENRM0HN
67490 MILES
12/06/2016
Repair# 0241236
Service: ELF-REPL FUEL PRESSURE GASKE T-IS250,IS350,GS300,350,450H
Description: ELF-REPL FUEL PRESSURE GASKE T-IS250,IS350,GS300,350,450H ~|~SAFETY RECALL ELF - REMEDY NOTICE - VARIOUS MODELS - POTENTIAL FUEL PRESSURE SENSOR LEAK. ~|~. ~|~67489 AGGB7A 310 PERFORMED ELF SERVICE CAMPAIGN.
67490 MILES
12/03/2016Repair# 241236C
Service:
Description:
Description:
Description:
Description:
Description:
Description:
Service: ROAD TEST
Description:
Description:
50194 MILES
06/15/2013Repair# 0126497
Service:
50194 MILES
06/14/2013Repair# 126497C
Service:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Service: ROAD TEST
Description:
Description:
46666 MILES
07/13/2012Repair# 0099827
Description:
Description:
45250 MILES
03/26/2012Repair# 0093131
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Service: ROAD TEST
Description:
Description:
Description:
42202 MILES
06/09/2011Repair# 0071947
Description:
Description:
41204 MILES
04/28/2011Repair# 067844C
Description:
41204 MILES
04/27/2011Repair# 0067844
40544 MILES
02/17/2011Repair# 0060979
Description:
Description:
Description:
Description:
35795 MILES
05/19/2010Repair# 0040932
Service:
35795 MILES
05/18/2010Repair# 040932C
Description:
Description:
Description:
Description:
30619 MILES
08/18/2009Repair# 0017660
23398 MILES
04/09/2009Repair# 0006431
20815 MILES
09/24/2008Repair# 0212711
15363 MILES
05/19/2008Repair# 0200931
15363 MILES
05/17/2008Repair# 200931C
10286 MILES
01/11/2008Repair# 0189053
7483 MILES
10/29/2007Repair# 0182418
5304 MILES
08/10/2007Repair# 0174956
1256 MILES
04/13/2007Repair# 0163960
428 MILES
03/22/2007Repair# 0161730
3 MILES
01/22/2007Repair# 0156286
What is the condition of the dashboard and door panels? When searching for our '08 IS250 a few months ago we limited our search to those vehicles where the dashboard was already replaced. Reason being IIRC I think the Lexus replacement program expired last year (2017). You can have it replaced yourself but it's expensive to have it done at the dealer. Of course if the dashboard and panels are good you are ok.
Don't worry about an auction car - most cars over 3 years old are wholesaled out to auctions by new car dealers - they usually only keep the creampuffs. The '07 sounds like a good car if the dash and door panels aren't cracked or sticky. Have a PPI performed and get the CarFax and if it's clean, go on KBB.com and look up the private party value. Offer the dealer that.
Congrats! From the service history it looks like the cam gear recall was done, too. We were a little worried about that when purchasing ours but from all of the reviews these engines are solid. Just passed 152k on ours so with only 76k you have a lot of life left in that car.
dychen85
07-17-14 10:05 PM
BBBsti LTD
07-08-14 09:31 PM
philliple
12-17-11 09:45 PM
