passenger map/visor light not working
Replaced the bulb and it still doesn't light up. I'm talking about the light under the visor. Thanks in advance for any suggestions
I've been having a similar issue. The light works intermittently, If I slide the mirror cover back and forth multiple times I can sometimes get it to work. Seems to me some wire is loose or corroded.
When you put in the new bulb did you try flipping it around and trying it again? I know when I switched to LED bulbs they only work in a specific direction. So I would have to flip it around if it did not work the first time.
