2006 is350 oil leak between engine and transmission
I have a is350 bone stock I just got the car and I have this major leak between the transmission and engine I don’t know what it could be I’m new to these Lexus’s I’m not sure if it’s the transmission or the motor has anyone ever had this problem
You said gasket
When I got on the gas a few seconds later lit was dripping oil a good amount I’m tryna put everything thing I saw out there soo i can find out what to do
looks like the engine oil pan gasket needs to be replaced. by the color of the fluid I'm certain its motor oil.
trans fluid is unlikely to leak from there. a trans leak would be further back if input shaft seal, for example you'd see red fluid at the trans bell housing.
There are plenty of places to leak oil from so don't go ripping the pan off.
Check the oil level, confirm it is not over full.
Take the upper covers off by the fenders and with a mirror and flashlight examine the valve covers and feed tubes to the VVT on both sides.
After that you need to get it up on a lift and look with all the lower covers off and see where it originates from.
Take a peak here:
That feed tube seen behind the pulley is a likely candidate to leak while the engine is running. Inspect both sides..
Take a peak here:
The rear seal is the most likely candidate which is zero fun to replace.
I can't vouch for if it can be done in car and/if the 1st ans 2nd oil pan have to come off to replace it.
If it can be done with the pans in place, the least expensive repair is pulling the transmission.
If it is misdiagnosed, a big waste of time and money.
Have you had it on a lift to look up with NO splash guards in place?
These are not known for crankshaft leaks at the rear seal.
You best pull the starter and stick a boroscope in there to confirm. Well unless there is an inspection cover to be removed.
What is the price range for something like that and would it be better to get a a healthier motor and transmission please lemme know your guys opinion
Remember, when you see oil in an area that doesn't necessarily mean that's where the leak is coming from...I've had leaks from valve cover gaskets that dripped down by the oil pan.
IMO even if the motor is at 200k it doesnt warrant an engine swap. Oil leaks are relatively easy fix and far less expensive then say sourcing another motor and trans. Like others suggest, if you cant confirm where the leak is coming from, taking it to a mechanic would be your best bet.
