Please Help! ABS, Brake Light, VSC, P/S lights on.
Hello everyone,
I have a 2008 Lexus IS250 with RWD, recently, I replaced the wheel bearings on my car after they went bad. While replacing the Rear Left wheel bearing I noticed I broke the wheel speed sensor, I purchased a new one and installed it and still had no luck getting the sensor to read the wheel speed, I figured maybe I got a bad sensor so I ordered a new one and replaced it again. After that didn’t work I tried replacing the Wheel Speed Sensor connection that goes from behind the rear seat to the wheel well, And I still had no luck getting the Sensor to read the wheel speed. I have been resetting the light with a computer that has ABS capability and the light usually comes on after driving it for about 2 minutes. With that same computer I can see live data for the ABS system and every sensor is reading the wheel’s velocity except for that Rear Left one. The code coming up for the ABS system is: C0215 Rear Speed Sensor LH Circuit
If anyone has had this problem or has any ideas on what it could be, please let me know I don’t know what else to do.
Thank you you for your time!
@Maca1281
Sounds like the sensor is no longer centered over the tone ring it is supposed to be sensing.
To confirm this, remove the sensor and physical look in the hole while rotating the axle (block vehicle and place in neutral with the brake off).
It is possible that while removing the bearing you dislodged the ring on the axle. However there may be a chance the axle is not fully seated to depth.
Compare from side to side if need be. This may apply to tone ring inspection too. With both rear sensors out, compare the position of the rings left to right.
Let us know what you find.
Hello everyone,
I am having the same problem. Did you figure it out? I’ve had my car pared for two months with the same issue. Please inform me if you figured it out. Thank you.
Solved
Yes, my problem was that the dust cover the ABS wheel speed sensor fits into wasn’t sitting correctly. As a result it was throwing the ABS sensor off just enough to where the sensor wasn’t reading anything. What I did to fix this issue was I removed the the dust cover from both side and my issue was fixed. I have also read that you can drill a larger opening into the dust cover so the sensor sits correctly. I did not attempt this because I was scared to drill too far and damage the bearing. Hope this helps. I know how much of a pain it can be.
Did doing this clear all 4 lights (ABS, Brake Light, VSC, P/S lights), or left some of them?
Hello, did you fix your issue? I am experiencing same on my is250 awd
ES2501990
19
10-23-16 07:49 AM
Globalinx
GX - 1st Gen (2003-2009)
03-04-14 01:17 PM
