How to disconnect subwoofer in IS250?
You'll need to remove the backseats, rear trim, and the rear panel/grille. It's fairly straightforward. The lower seat pop out and the upper portion you'll need to lift upwards to unhook them. There's a video on how to do this. Also, there are 4 bolts that are 12mm (I think), then you can remove the side interior trimming.
I removed mine when it **** the bed, I believe the connector is under the rear deck panel which does require removal of the rear seat and trim panels.
(but it's been a while so maybe see if you can access from the trunk)
FinLIFE
09-23-08 07:11 AM
