Heater blower not working as it did yesterday
As you probably know, when the heater fan is on Hi its really loud and moves a lot of air. I usually keep the vents set to windshield and feet but some always comes out of the vents above the climate control panel.
Today I noticed nothing came out of the upper vents, so I went from Low to Hi and noticed it's way quieter than it should be. I then selected just the upper vents and it barely moved any air.
As my windshield began to fog I hit the front defrost button and it was so much quieter than it should be, usually that mode is loud AF.
After getting to work I popped out the cabin filter, it had some tree debris which is normal for where I have to park at home, but nothing that should clog it, I cleaned it out and put it back in and turned the blower to Hi.
There was a lot of suction at the filter, I tried to lift the filter out as the blower was sucking away and basically couldn't do it so I turned the blower off, lifted the filter up an inch or so and turned it back on, it had a lot of suction there but as I've never ran the blower with the filter exposed I don't know if that's normal or not but it still didn't sound as loud as it should.
I'm not sure if something is clogged but I don't see what could be clogged as it's sucking right from the filter which is infront of me open to the interior.
I've had a blower motor go on my CRX but it was a completely different story, I've also had the resistor go on my old CRX and that again was a completely different story.
Hoping someone has more experience with this chassis that can help me out here.
I got a new cabin air filter and replaced it, after putting it in and holding my hand on top of it with the heat cranked I could feel a lot of air moving past my hand which I didn't with the old filter, the loud sound of the blower was back as well.
So, although the filter wasn't very clogged, it turned out the bottom side was quite wet.
mason2006
01-09-09 07:33 AM
