Dead Board or just a great Car?
I was just thinking the other day, I'm used to visiting BMWs Boards (I've owned like 6+ and still own one) and noticed that after some time, there's always posts about this or that problem. In fact the majority of new posts tend to be "how do I fix this?" or "what this noise or error light or help I'm stranded."
In looking at the 2IS posts, it really seems boring in comparison (a good thing)! Most of the posts are about modifications (but even then, they tend to be limited. It seems like there are a lot more mods available for BMWs, but I do see tons of 2IS on the road, so it's surprising there aren't more). Or the posts are related to maintenance or wear/tear items (like o2 sensors).
It seems the biggest ones are:
Sticky Dash
Various Airbag Recalls
Carbon Buildup on 250
Rarely are they posts about powertrain problems. And we're almost 5 years past 2IS production. That's just AMAZING. I might just keep mind till the wheels fall off.
Sticky Dash
Well it is a Lexus :P
everything on CL seems to come in waves
should I get coilovers?
how do I add power to the IS250?
what aftermarket headlights should I get?
what aftermarket taillights should I get?
Can I run staggered on AWD?
Am I experiencing carbon buildup?
what exhaust should I get?
what are the common problems with 2is?
and more recently... am I experiencing alternator failure?
regarding the powertrain... there was a time when a lot of threads were showing up like - my car isn't going into x gear, things about when and or if you need to replace the transmission fluid, fixing shift solenoids and the such.
there's a lot more but I can't remember them off the top of my head right now.
2013FSport (01-26-19)
Interesting, I have seen a couple of shifting/transmission issues but it seems like it was on older cars, more recent ones, like 10+ not so much. But even then, that's only a fraction of what you'd see on bmw message boards. Every other post is coolant reservoirs blowing up, alt issues, turbo problems, timing chains failing causing catastrophic damages, fuel pump issues, carbon build up, valve seal leaks, injector issues, trans problems (though the current ZF 8 speed is very reliable) and other things and the worst part, these are complaints that creep up after only 2-3 years.
It seems like BMW boards focus more on what to fix, while Lexus boards focus more on how to cosmetically modify (followed by performance mods).
It's just amazing that Lexus can pull off cars that are now 13 years old (for 06 models) and usually the posts for the 350 at least, revolve around minimal drivetrain issues. I don't understand why BMW can't just look at how Lexus builds their cars and copy them. I think the worst issue on the 350 were the initial valve spring problem (?) and most recently that fuel delivery recall. But these were both covered and taken care of and it's not like it's rampantly causing issues-it's more preventive.
Also, it's not like BMW charges LESS for their cars, they charge a premium, so why not make them better? I've had EGR rubber tubes go brittle after 40k miles.. 40k!! I have a 2000 4runner with 200k miles and all the rubber tubes are still supple and pliable. Go figure.
PS-I just ordered the -42 IS-F Steering ECU :-) really looking forward to it as that's been the ONLY complaint I've had about the car since I got it... the lack of steering feel and how "light" it is at speed. I'm looking forward to installing it. I was able to take care of my other issues like handling with F Sport springs/shocks/sways and the engine note that's a bit blah, with the f-sport intake (gives it a nice rumble). My last issue was the steering feel and if this is fixed, then I've got 8.5/10ths a BMW with 300% better reliability, LOL!
I think think the IS is one of the best kept secrets, but it does need a little mod for "drivers"
Lol, even the cupholders have to be overengineered, otherwise you would be thirsty while you waited for the tow truck. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Sticky Dash
Sticky Dash
I wondered the same thing when I joined this board a month ago.
Wanted a sporty sedan under a below 10k that was powerful and reliable. I considered the usual suspects including the e90 328i. The Lexus is not as driver focused as the BMW, but the addition cost of ownership wasn't worth it to me. Bimmerforums basically made my choice for me.
Granted, BMW manages to just get it right, from the showroom. My problem is what happens AFTER you drive it off the showroom... it can be a very unpleasant ownership experience.
I'm being very hopefully. It's just SOO dead at speed, well really, it's just dead all over, LOL. A little more weight so you can feel the g-forces against the tires during a curve would be very welcome. Or basically anything that makes me realize SOMETHING is happening up front, haha.
LOL.. Ironically, I'm a board moderator for one of the largest bimmer boards, but after looking at the current generation 3 (after owning 2 E46s) I just couldn't get myself to fall into that hole again. The IS is just a good car overall and can be made to ALMOST drive as well as a BMW, but requires that you KNOW what you want and then "tune" it in with mods--it will admittedly never be 100% as good a BMW (in fact, I don't think it can reach 90%) as far as driving characteristics go. But I don't get an opportunity to drive any car to that limit on a regular basis, so it's nice having a Lexus that can do something really well the other 98%.
https://www.youtube.com/watch?v=ABO2uBdScjE
ISFFUN
Performance & Maintenance
09-29-16 10:22 PM
