Troubleshooting (2008 Lexus is250) car wont start
Hey everyone. Ive seen many post regarding this issue, car not starting. Not sure what it can be. Is it my camshaft positioning sensor or my fuel pressure sensor. Please see below to see the lights on my dashboard.
thank you,
thank you,
I don't see a MIL on so I would say your battery is probably bad. Get it load tested, and report back. If you have and OBDII scanner with ABS capabilities. You could scan the car for a code. Also if you have an DMM turn the ignition off, and check voltage on the battery should be 12.66 volts DC.
Hey Mike,
i dont have my battery light on though. And i did buy a new battery. When i press my push start it'll try to start but womt turn over. When i try a second time car wont make any noise. Gauges engage but engine will not start. Dashboard stays on as well.
I bought the battery on Friday. Ill try jumpstarting it.
i did check cables just last night and tighten them up but no luck. It cranked again but did not turn over. Just fustrating lol
No. So what happen was, Friday after work turned my car on. Drove from Yorba Linda to Long Beach. Parked my car. It sat there the remainder of friday, all day saturday and sunday. Monday morning when it was time to go to work i steped on my brake, pushed my engine starter and almost turned on but not quite there. Took my battery to the shop told me it was a bad battery. Got a new one but still nothing. So yesterday i tried tightening it up as it was as tight, left the negative kinda lose. Cranked it again and nothing. The only thing it was doing before was that my rpm were kinda low. Around 600rpm while in drive.
Not sure if you're in a cold climate but in Toronto the exact same thing happened to mine it wouldn't turn over after being left for 3-4 days in the cold with all those same dash lights. Its just the battery, a boost instantly started the car and then you'd want to drive for a bit to let the battery charge
Trying to start the car in the beginning caused it to throw a bunch of crankshaft engine codes and check vsc message. The car seemed to run perfectly fine after the boost so I cleared the codes and it hasn't returned which is good. If the car starts and runs normally after the boost you should clear the codes or else the dash lights and check vsc will stay
ahunny22
03-17-15 01:11 PM
