"11 IS350 fuel rail recall...make CEL turn on?
We have a 350 and I've been meaning to do it but today the CEL light came on....
P0441- Purge Flow Incorrect
P-0455- Evap gross leak
Recall is fuel system related so I'm thinking it could be the cause. Car has given us no other issues over 3 years except a headlight. Dealer said who knows, could be could not be. And the people who talk on the phones know nothing about the cars.
Did anyone else who had this done have a CEL caused by it?
Not a silly question, that was the culprit. It wasn't "off" but it was not screwed tight enough. Spouse's car. I figure another 50 miles or so and it'll turn off.
No connection
If you a referring to the fuel pressure sensor gasket replacement, a lot of customers has had fuel pressure sensor issues after recall was performed. This is around a 1500-2000 dollar repair because the dealership doesn’t sell the sensor separately. They replace the whole rail with sensor. I just recently experienced this myself. If I had a chance to do it all over again, I would have never let them touch my car. They also broke a bolt in the fuel rail and didn’t own up to it. So, I’ve had to replace the fuel rail twice since this recall was performed. Good luck!
If you a referring to the fuel pressure sensor gasket replacement, a lot of customers has had fuel pressure sensor issues after recall was performed. This is around a 1500-2000 dollar repair because the dealership doesn’t sell the sensor separately. The replace the hole rail with sensor. I just recently experienced this myself. If I had a chance to do it all over again, I would have never let them touch my car. They also broke a bolt in the fuel rail and didn’t own up to it. So, I’ve had to replace the fuel rail twice since this recall was performed. Good luck!
Gasket 90430-12026
I'm assuming the OP is referring to the newest recall relating to the fuel dampener/delivery pipe, not the old fuel pressure sensor gasket recall. Completely different recalls. But. for future reference, a newer version of the sensor (which includes the rail) is available for $300 online. An older version of the sensor is also available that you can buy alone for about $30 (I went this route when my sensor decided to kick the bucket). If you plan on tackling this, you absolutely need to buy a new gasket for it too, you can't reuse the old one unless you want it to leak. It's really not a hard job to DIY, I have a post somewhere on this forum detailing the process (or you can just find the NHTSA document about how to do it)
IS350, I have received a new recall. It is not the older Fuel Rail recall (which has been completed). Should I take it in? I will bring my recall document, scan and post.
Recall is done, and CEL went off after a few days. Loose gascap. The dealer even filled the car up, Lexus does that for recalls. Good customer service.
Raykwon02
08-03-16 01:26 AM
Patrickleo
06-27-16 09:42 AM
