Muffler Delete on 08 IS350??
hey guys, i want a little more sound out of the car and heard the muffler delete and sounds just how i want it.
should i go fullsend and get a muffler delete or proper exhaust setup? and if i do go for the muffler delete will i be experiencing any droning?
If I were you I might reconsider. I wanted a similar sound, however going for a straight muffler delete will come with quite a bit of drone. What I got done instead was have the resonator deleted and get a set of custom mufflers. This gave me exactly what I wanted with minimal drone. Try going to an exhaust shop and see what they can do for you.
I had a muffler delete for a year and a half and never experienced drone. Drove at various RPM's, distances. Nothing. "Quite a bit of drone" is a stretch.
This is my current setup: Vibrant resonator and muffler deletes and still don't experience harsh drone unless I really step on it while on the highway at like 2700rpm
Mitrin (04-04-23)
Here is what I did:
RR Racing CF intake tube
K&N drop in filter
F-sport air box (open in front - left the intake snorkel)
Muffler delete from axel back w/ custom, black tips
I left the resonators on.
Sounds GREAT! Several have mentioned it sounds like a GTR. Only "drone" is around 3rd and 4th gear between 2k-3k and only in that range at low speed. Freeway is fine, local roads are fine.
You can also ask them to cut off the stock tips form your mufflers and put it back on your car.
For me, I paid $300 CAD. All new piping, larger piping from the axle-back and F Sport style tips (4") Once the pipes build up enough carbon, it tones down a bit, but cold starts are a little loud at first.
It depends on what state you live in. I’m in Atlanta, Georgia, and here they don’t check exhaust. I also don’t recommend deleting the resonator, it will cause the exhaust to be very raspy though, which is why I only did the muffler delete.
My opinion is that v6 cars usually sound terrible and it's hard to get the exhaust right without drone. I think swapping out the oem mufflers with flow through mufflers is something to consider. You will have plenty of noise when you floor it while keeping the volume lower on the highway.
