Is there any difference in center console trim between 2006-2008 and up? Is it possible to use the grey wood trim from the newer cars or are there different plugs/fitment or do I have to use the correct mode Years?
IIRC, center console trim will fit fine. It's the window switch trim that will be a problem as they changed the plugs for the switches across the years (06-08 needs to stay with 06-08, and 09+ with 09+)
