Intermittent AirBag Light
I've discovered this strange solution to the problem but I'm looking something more permanent. If I get into the car shut the door and remain completely still from the point I press the start button to until the airbag check is complete then the light will go out. If I get in and press the start button then proceed to shut the door or move around in my seat the airbag light will remain on.
Check this connection out; move it around in an attempt to get it to "reseat" itself. Report back if it helps or not!
https://www.clublexus.com/forums/is-...ml#post8141845
Someone posted in another thread they received a similar letter in Canada for a warranty enhancement program W34. I'll give my dealer a call and see what they say. I think I'll have more luck knowing both markets have received some sort of communication in regards to this.
Usually I get stuck in a loop because I have US model vehicle in Canada. So some of these customer support programs are only available in the US and the local dealer won't perform them. I missed out on the dash replacement because of this.
It was Northwest Lexus. Did you ask about the W34 warranty enhancement program? I never ended up going in since the light went away on mine. It's possible the just booked the appointment for me but would have told me the same story once I actually went in.
On my car if someone move the passenger seat too far back the light will come on.
