How much to fix these codes?
Pretty much anytime the engine gets invalid temperature readings it wreaks havoc with emissions devices.
But honestly that many is like your ECU has a bad ground or corrosion took over a connector. If it were mine, reset and see what happens next.
If a bunch repeat, have someone pull apart critical connections between the ECU and everything else. A bad ground comes to mind.
