Rim/tire size on lowered Lexus
I just lowered my 07 IS250, said it was 1.5” it was more like 3”. I ordered a set of xxr rims 20x9 35mm offset, I’m going to be running a tire size of 26x8.5. You experienced Lexus guys, do you think this set up will fit? I was told by friends they don’t think it will. I can’t return the rims and I have a car show May 17th. Will I be okay or am I SOL? What do you guys run and how low are you?
What suspension set up are you using?
Are they coilovers or just springs? The offsets seem ok. The overall height is what your issue may be I suppose. I would look at a tire conversion calculator and see how close the setup is to OEM.
