Wizzing at start wont crank
Wizzing noise sounds like vacuum cleaner no crank
Bad starter? Low battery and pissible Bad alternator?
coldone (05-23-19)
If the cables are good, and the solenoid wire applies enough energy to power the starter solenoid but not engage the solenoid and move the bendix, your stater is bad. You could try a new solenoid but likely need a new starter.
Did you try jumper cables as ya, in some cases a low battery can lead to no engagement but the motor spins.
