CD changer problem
CD changer problem
Hello,
I've searched the forums and have not found the problem I'm experiencing so here goes...
So my cd's will load and unload fine with no clicking or noise. And they will play but only for 30 to 90 seconds and will then stop and the display will read "check" and no further audio will be played. I tried cleaning the lens with this... https://www.amazon.com/dp/B003EEMDMC/ref=cm_sw_r_fm_apa_i_.Ur2Cb9WQ13Q3
It's a cd lens cleaner disc.
But it didn't work. I would much rather keep the stock CD player then go after market or paying big $ for a new OEM unit. Any other ideas would be greatly appreciated. TIA.
You can always swap out your unit with another stock one. But honestly just buy a AUX to Bluetooth adapter with a groundloop isolater and call it a day. $20 fix. It will sound just as high quality with the ground loop isolater and you'll be wireless to your phone
MPow on Amazon are high quality and work great. Just make sure you buy one with a isolater and one that doesn't run off battery. The battery just adds static.
Neo
10-22-02 06:35 PM
