P0504 after brake switch replacement.
Hey guys hoping you can help before I sell the car as is/for parts.
I got the car and it wouldn't start. I ran diagnostics and got 3 codes (P0504, P2118 and P0705)
I checked the fuses in the engine bay and cabin.
That took care of P2118 and P0705 but P0504 is still there.
So I replaced the brake light switch.
Code keeps coming up.
Here's whats going on with the car when I try to start it.
When I open the door the car makes the sound that the door is open.
I push the brake, the light on the start button doesn't come on.
I push the button, it turns orange.
I push it again, the lights on the dash come on, the engine makes a sound (I think fuel injectors) but does not attempt to start and the display tells me what doors are open and to check system.
When I hit the brake my brake lights don't turn on but my blinkers work.
I know there are more fuses in the trunk but I cant use the key to get in, the button on the dashboard isn't working (not sure why not) and I cant reach the escape release in the trunk from inside the car.
Is there a way to take out the seats or fold them down from inside?
Any help would be appreciated seeing as I need the car to get to work and Lyft is getting expensive.
The main bus bar fuse usually fails if the car has been 'jump' or 'boost' started with a battery pack or another car And the polarity of the cables gets crossed and then the battery/car is connected up with reverse polarity!
Could this have been the case by you or previous owner?
paul m.
paul m.
devyvalent
05-31-18 06:18 AM
RWederfoor
GS - 1st Gen (1993-1997)
10-24-11 08:55 PM
