Vinyl wrapping engine cover
Old 07-11-19, 02:36 PM
lexus-is2
lexus-is2's Avatar
Default Vinyl wrapping engine cover
How hot does the plastic engine cover actually get? It I was to wrap it in vinyl will the wrap hold up in that heat? Considering the piece is plastic, I'm thinking it may be able to handle the heat? Problem with wrap is it stretches when hot doesn't it?
Old 07-14-19, 08:16 AM
MAizz
MAizz's Avatar
I would opt to plastidip over vinyl wrap from experience on the covers. Zero issues with dipping on several vehicles. Vinyl wrap doesn't always stick to the plastic well.
Old 07-14-19, 07:07 PM
primavera
primavera's Avatar
If I was into that I would look into hydro dipping.
Old 07-16-19, 01:06 PM
Ken167
Ken167's Avatar
I also thought about wrapping the engine cover in carbon fiber vinyl but I worry it may melt/distort or catch fire
Old 07-16-19, 04:21 PM
MAizz
MAizz's Avatar
Just get real carbon fiber covers
Old 07-16-19, 10:37 PM
flowrider
flowrider's Avatar
Received 1,899 Likes on 1,340 Posts
^^^^That's Impressive
Lou
Old 07-17-19, 08:38 AM
2013FSport
2013FSport's Avatar
Received 1,518 Likes on 1,262 Posts
A wrap is no more likely to catch fire than anything else under the hood. Even rodent nests full of dry nuts straw seem to resist spontaneous combustion so that is the least of your worries.
Getting the oil film off the cover is your concern. Use the right product and you should be fine. Well unless someone sprayed it with silicone!
Old 07-18-19, 02:07 PM
Ronin559
Ronin559's Avatar
I would not worry about the wrap catching fire, you can heat them up pretty high when installing them. My worry is that the heat would cause the wrap to soften and lift or even slide of completely as time goes by.
If you just want to change the color I think the Plasti Dip is the way to go, or just go with a carbon fiber cover like @MAizz .
TCM55
IS F (2008-2014)
06-03-21 12:28 AM
Ltaboso
IS F (2008-2014)
12
02-04-15 11:56 AM
Meraki Autoworks
IS F (2008-2014)
01-19-12 07:31 PM
SC3coupe
07-10-10 02:46 AM
Quick Reply: Vinyl wrapping engine cover
