06 Car wont start, probable cause for these codes at once?
Old 07-17-19, 11:08 AM
jjf902
jjf902's Avatar
Default 06 Car wont start, probable cause for these codes at once?
A couple days ago my car needed a jumpstart to get home, tested the battery and it wasn't taking any charge. So I replaced it. Worked fine for a few days. As I was driving yesterday my check VSC and other lights came on. Steering was stiff and the dash lights came on but I made it home. went to start it today to see if it would start but nothing. Tried a jump start. Nothing, besides a buzzing noise from the engine. So I scanned the codes. C1223, C1241, C1381. Since it wont start at all, and even if it did start it probably wouldn't make it to the shop that is a couple streets down. Yesterday was the only day I experienced the check VSC. Is there something to fix, that throws all 3 of these codes at once?
C1223 - ABS CONTROL SYSTEM MALFUNCTION
C1241 - LOW OR HIGH POWER SUPPLY VOLTAGE
C1381 - POWER SUPPLY VOLTAGE OF YAW/ DECELERATION SENSOR
Yaw rate sensor caused all 3 codes?
Thank you in advance, any help is appreciated.
Old 07-17-19, 12:50 PM
Bichon
Super Moderator
Bichon's Avatar
Loss of power steering is a classic symptom of a bad alternator. I'd start there.
Old 07-17-19, 12:54 PM
jjf902
jjf902's Avatar
Thank you for your reply. Even with the codes it could just be as simple as the alternator?
Old 07-17-19, 12:59 PM
Bichon
Super Moderator
Bichon's Avatar
Yes. Lots of electronic modules in the car stop working properly when they don't have an adequate power source.
Old 07-17-19, 01:19 PM
jjf902
jjf902's Avatar
Thank you! I'll swap it out tomorrow and see.
Old 07-18-19, 01:53 AM
xxmariolxx
xxmariolxx's Avatar
Have fun. I just did mine a few weeks ago. I can now do it in probably an hour or so but doing it the first time was a pain in the ***. Hoping that solves your issues though
Old 07-18-19, 06:08 AM
2013FSport
2013FSport's Avatar
Received 1,534 Likes on 1,276 Posts
When all those computers went below voltage, they threw codes on their dying breath. Hopefully you put a charger on that battery as leaving it dead for days ruins them. Even if brand new!
Old 07-24-19, 11:30 PM
jjf902
jjf902's Avatar
Thank you. It was the alternator.
Old 02-27-20, 01:19 PM
shelby7
shelby7's Avatar
did you have a good battery trying to start the car and it still wouldn’t because alt was bad? Or did your battery get low then it wouldn’t?
stasharp
ES - 5th Gen (2007-2012)
18
10-23-23 10:56 AM
Benjam1n
03-11-18 09:28 PM
Bserrano
01-29-18 04:25 PM
Mason123
03-09-16 08:01 PM
L3XOTIC
05-09-07 01:00 PM
Quick Reply: 06 Car wont start, probable cause for these codes at once?
