Should both fans be spinning on the radiator dual cooling fan assembly???
Old 08-09-19 | 02:56 PM
2013FSport's Avatar
2013FSport
Originally Posted by seanmwple
Tried the test lamp. No fan spinning still.
^^^ "Tried" with no conclusion isn't a clear answer IMO as I'm not there. The only confirmed thing I know is the one motor is dead as you jumped it w 12v and it didn't spin.
Do you have an ohm meter?
Read your owners manual but I think RAD1 RAD2 are the fuse labels. Could be mistaken.
Old 08-09-19 | 02:59 PM
2013FSport's Avatar
2013FSport
FWIW a kind gesture goes a long ways towards continued support! Just sayin...
primavera (08-11-19)
Old 08-10-19 | 09:29 AM
seanmwple's Avatar
seanmwple
Sorry just frustrated. I checked those fuses and they looked good.
So I had the shop put on my new shocks and mounts and had them look at my a/c. They said it reclaimed .66. They recharged it for me. They sprayed it down with the dye so they can see where the leak is coming from. So if the cooling fan isn't blowing ever could it be possible that there isn't a leak and it's just the cooling fns not operating being the reason the a/c doesn't work properly?
Old 08-10-19 | 12:30 PM
seanmwple's Avatar
seanmwple
So I swapped around the relays for FAN1, FAN2 & FAN3.
When I unplugged FAN2 or FAN3 the radiator fan on the passenger side turns off. Do those relays both control that specific fan??
I didnt noticed anything when switching around relays in the FAN1 spot.
Old 08-11-19 | 06:31 AM
seanmwple's Avatar
seanmwple
Anyone else have any input for me
Old 08-11-19 | 10:37 AM
2grfan's Avatar
2grfan
Are the fan plugs the same? Could you swap them? Might have to disassemble them.
Looks like they’re under $150 on rockauto.
Old 08-11-19 | 03:29 PM
2013FSport's Avatar
2013FSport
You still didn't answer the question or say thanks! The advice you need has been spelled out. Read up....
Old 08-11-19 | 03:30 PM
seanmwple's Avatar
seanmwple
The entire assembly is around the same price from what I am seeing online. Unless the full assembly doesnt come with the motors???
As for the plugs... are you referring to the connections that go into the motors? They aren't long enough to reach the opposite side.
Old 08-12-19 | 03:50 AM
2grfan's Avatar
2grfan
I figured, that why I said you may need to disassemble them.
Old 08-12-19 | 08:59 AM
DennisMik's Avatar
DennisMik
The fan assemblies that auto parts stores, on-line and brick, have the fan motors. That is why it is called an assembly. If it didn't have the fan motors, all you would be getting is a plastic shroud.
But those assemblies are not Lexus parts, which is why the price is less. And sometimes the fan motors are not 2 speed like the factory used.
Old 08-12-19 | 10:38 AM
seanmwple's Avatar
seanmwple
So the link below looks like the right part correct? Seems like a rather easy diy job as well??
https://www.ebay.com/itm/2007-LEXUS-...kAAOSw5zVdI8W4
Old 08-12-19 | 02:07 PM
DennisMik's Avatar
DennisMik
The part number for the motor on e-bay is for the left side. It will fit your 2012.
As for how easy it will be to replace, I don't know. Haven't had to replace mine yet.
Old 08-12-19 | 03:45 PM
seanmwple's Avatar
seanmwple
I cant find any "how-to" online showing how to do this ugh.
Kurtmaramb
06-02-18 03:33 PM
SteveCordo
04-22-17 12:17 PM
skytechja
GS - 1st Gen (1993-1997)
10-10-16 01:43 PM
zero44
10-23-14 01:14 PM
Jinx2006
Performance & Maintenance
20
05-23-07 01:11 AM
Quick Reply: Should both fans be spinning on the radiator dual cooling fan assembly???
