My 2006 is250 still needs jumps....😢
Hey just a follow up on my lighting problem, I seriously want to thank whoever gave some advice on the problem. I finally got it fixed but car still loses power a hour after I drive it. So recap, Lexus told me it was the battery. Got it Replaced, car still don’t hold charge. Got the alternator changed two months later, still got the issue. Replaced the starter relay still need jumps. Auto zone says everything is good but I’m not getting it. I remember when I was changing my o2 sensor on the driver side the wire sparked when the special wrench mushed up against it and the car cut off.... I know I shouldn’t have had the car running but I need the heat for the PB blaster to get it off. I had to replace the injectors fuse because it blew as a result. Can anyone help me with this problem? Below I left a video of my voltage reads using a power probe 3. Tell me if the readings are right. Thanks in advance
