2009 is250 AFS HID housings- High beam LEDs
Hello, I am replacing the halogen high beams on my 09 is250 witb an LED kit from Xenon Depot and with the bulbs installed I cannot get the access cover back on over the bigger LED.
Is it possible to keep the cover off?
I imagine it would allow moisture into the enclosure but I'm not sure
Which bulbs did you get exactly from Xenon Depot? Normally you need to drill a 1-inch of the covers with a drill bit for the ballast to fit through the outside of the headlight. If you got the LED's with the metal tabs you can probably bend them. I don't recommend keeping the covers off as you might end up with moisture or water inside the headlights.
Thanks for the sanity check, I will be contacting XD tomorrow.
So to update, I was able to successfully swap out the factor halogen high beams to Xenon Depot LEDs. With some careful arranging of wires and cooling fins everything fit behind the covers. Pics below of the install process, showing the hole drilled and grommet installed for wire pass-through.
I disabled the DRLs with techstream because I drive with the headlights on always. I personally think the high beam output with the LEDs is much better over stock. I love how bright they are and I love how quickly the LEDs turn on compared to halogen.
https://www.xenondepot.com/h4-philips-12953BWX2-LED-Bulb-p/12953bwx2.htmhttps://www.xenondepot.com/h4-philips-12953BWX2-LED-Bulb-p/12953bwx2.htm
