help, headlight out
hi, so I was changing my HID ballast on the left headlight and when I connected the light, the left headlight turned on but the right didn't turn on, the only thing on was the parking light for the right light. Car shows a right turn signal when lights on the left are on. also, when hazards are on, the left turn signal is normal but right turn signal fades away in the cluster. I'm not positive if its a wiring issue but please, if anyone has any idea what this could be, please let me know.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Thanks, Serg
Thanks, Serg
also, i took the headlight off and i found that there is a wire leading from the ballast to a end that looks like it goes in with a screw. what is making me confused is that the right light has that on the ballast but the left doesn't, do you happen to know what it is?
With a DMM or 12v test lamp you need to verify the wire to the connector is grounded and the wires after the connector are grounded.
Make a 1 year subscription to www.alldatadiy.com and read the schematic. Its like $22.
Not exactly but best guess is with high voltage potential; it is ground to the chassis. Does it look factory installed?
Thank God that it wasn't a car issue that caused it but a water leak issue.
