Light bulb E=MC2
Man i am so confused. I been on forums, google and youtube. I have both headlights out. My fog lights work. High beams work. DRL lights work. I dont know if the light that is out is my low beam or called a low/high beam. I have a 2006 is350 with the lights that move up and down when you start the car. I see some people bye h11 light bulbs and some get ds4. I dont know which ones to get.
Remove the engine covers and pull the bulbs. If you notice a yellow high voltage sticker on the HL housing its HID. Otherwise standard. You should pull it apart before buying and check the fuses and connections to see what's wrong anyway.
pavelis300
IS - 1st Gen (2001-2005)
01-23-14 01:32 PM
