Rear sway
Rear sway
I just installed a fsport rear sway on my 07 350 but I realized after install tapper was upside down but the bar fit does it make a difference if the sway bar is upside down or not at all also I have the afs light now blinking in my dash how do I fix this as well
So the actual bar itself was mounted upside down? From the pics I see online, the bar appears to be a "flat-plane" style bar. So either way, it should work the same. But I'm so OCD, I'd have to fix that! LOL
https://www.clublexus.com/forums/att..._bracket_1.jpg
Sway bar orientation shouldn't matter unless you received one that had the drop in it for cars with the full size spare (which were overseas only, e.g. Australia)
