P/S problems help please?
So I have a 2006 Lexus is350 and in this last week my power steering light has come on the thing is sometimes it appears and disappears,but recently it will appear and makes my steering hard,but if I turn the vehicle off the light will disappear and it won’t appear again until I turn it off and turn it on again or if I’m idle it will pop up again.I already tried scanning it with an ob2 scanner and nothing came up so idk what can be wrong with it I’m guessing the module or the rack?
So after two weeks I finally was able to find the solution. What ended up happening was that my rack and pinion had failed,but not only that my harness that was connected to it was severed like somebody had cut it and it was really hard to find the culprit hence the time delay to respond.Anyways we put a remanufactured pinion and replaced the harness and the power steering light went away and good as new sucks it took that long because like I said we scanned it and everything and the ecu wouldn’t send signal because as I mentioned we ended up discovering that my harness was severed but it was hard to find it at first since the wire that was snapped was like hidden.
The thing is gville the it looked like if something/someone cut the harness which is crazy. I think it was just a freak accident because what are the odds right?anyways no I took the covers off ever since this car has been giving me problems since I’m always working on it,or I have people working on it so it’s a hassle to put all the plastic covers back on and take them off. Also the covers don’t cover that area since it’s already covered by the battery and the P/S ecu lid. Anyways glad to found the problem and in the future if that ever happens to any other user they should first check their harness and then proceed with the steering ecu and finally the rack and pinion.
Hello I have a 2008 IS 250.. P/S lights is on and car won’t start.. hook obd scanner up but it won’t scan either.. any advice would be greatly appreciated
Does it start up when you press the start engine?or is it just dead?if so do your lights turn on if they don’t it could be your starter.As to the p/s it could be your ecu or your rack and pinion or in my case my rack and pinion harness was snapped.
Car won’t start..lights works.. with the PS light on it won’t allow the obd to scan either.
Then it might be your starter that’s what happened to my Lexus it wouldn’t start it was dead but the lights would work.as to your p/s light it could be your ecu or your rack and pinion.Cheapest fix would be replacing your ecu and seeing if the light goes away but you would be better off having a mechanic look at it.But that might be your problem with your p/s is those two things most likely again only a mechanic can tell you for certain but that might be what’s wrong with your car.
So what you are saying that the scanner can't communicate with the ECU? If so you probably have a bad fuel pressure sensor. This is why the car won't start. Search threads on this it comes up every time. You can disconnect the fuel pressure sensor, and it may start once. Then probably die out shortly, but one tell sign of no communication from the OBDII port. Is a bad fuel pressure sensor.
91LS400LEX
12
11-15-09 02:21 PM
