Rough idle at start with codes
I started my car today and it was running rough, engine light came on. Shut it down restarted and ran fine. Checked codes PO172 and PO175 bank 1 and bank 2. Cleared codes and it seems to be running fine. About a month ago car started then died but haven’t had any issues till now. Mass air flow sensor ?
It does have live data. I’ll watch it, And look back on some old posts what the values should be.
I panicked when the light came on. Last and first time was due to a valve spring failure causing the motor to blow.
The "started, then died" comment sounds like what happens right after you have the battery disconnected for a little bit. It does this normally upon the FIRST re-start after the "reset" (aka, having the battery disconnected).
Have you messed with the MAF or the intake recently? Perhaps a slight leak somewhere where something wasn't fully tightened...perhaps the tube onto the TB?
No changes for months. I cut the air box about 2 months ago and it’s been fine since. Our temps here dropped about 20 deg since last time I dove it which was only a day before.
I plugged my scanner in today while driving. Not sure what the values should be but it looked good. Lol. At idle was about 8 under throttle it would go up.
At idle what's your fuel trims look like? Short and long term?
Those number look ok. One question do you have an after market filter in place? I notice this with mine having an AEM dryflow. It will add fuel on idle bank 2 to to 5% long term. With stock filter all my short trims will be 0 longs will be -2 to -3 both banks at idle once warmed up.
jre1638
RX - 1st Gen (1999-2003)
04-28-11 10:07 PM
