Red SOS Light On All The Time?
I noticed tonight that my 2012 IS350C has a red SOS light that is staying on constantly and I have no idea what it means. All the manual says is to contact Lexus dealer. I do not have a Safety Connection subscription. Is there a way for me to check codes or other items to determine if I actually do have a problem?
Regards,
Florida Jack
Regards,
Florida Jack
Regards,
Florida Jack
https://lexus2.custhelp.com/app/answ...button-mean%3F
Apparently it means you are no longer subcribed. Though yours is staying on. Indicates a malfunction of some sort.
https://www.clublexus.com/forums/rx-...sos-light.html
I have a Safety Connect subscription now. In an effort to track this issue I decided to subscribe. I went through the process, called the 1-800 number and chatted with a rep which yielded no resolution. I can connect to Safety Connect when pressing the button in the car and all seems to be well, but they did say there was a problem, but no alerts. Also, I am not seeing my car in the "Lexus App." Since it is a 2012 it is not Enform enabled, but older technology. I will continue to update as I work the red SOS light.
Regards,
Florida Jack
Regards,
Florida Jack
Regards,
Florida Jack
Regards,
Florida Jack
2013 and mine is on all the time too. Lit red that is. No subscription. Guessing its so you can find the button?
The Enform APP is not receiving data from my car as best I can tell. I've had the APP installed for a month and nothing at all from the car.
Overall, I'm not worried and will have it checked when in for a normal service.
Regards.
The "SOS" text light is NOT supposed to stay on. The 3 second single red light coming on and they going off is normal.
From the owners Manual for applicable USA vehicles 2009 and up. A picture states SOS text is on always.
Safety Connect LED light Indicators:
When the “ENGINE START STOP” switch is turned to IGNITION ON mode, the red indicator light comes on for 2 seconds then turns off. Afterward, the green indicator light comes on, indicating that the service is active.
The following indicator light patterns indicate specific system usage conditions:
●Green indicator light on = Active service
●Green indicator light flashing = Safety Connect call in process
●Red indicator light (except at vehicle start-up) = System malfunction (contact your Lexus dealer)
●No indicator light (off) = Safety Connect service not active
/done. GL...
/done. GL...
/done. GL...
/done. GL...
GrizzlyMan (03-30-21)
