OBD Apps | Torque Pro & OBD Fusion with PID pack
Old 01-05-20, 11:13 AM
2013FSport
2013FSport's Avatar
Received 1,519 Likes on 1,263 Posts
Post OBD Apps | Torque Pro & OBD Fusion with PID pack
Let's talk about data collection from Torque Pro and OBD Fusion. Considering 99% of us have smart phones, these apps make great tools for viewing what your vehicle is doing behind the scene. Specifically I would like posts regarding what does and does not work. An example is the Fusion App when coupled with the Toyota / Lexus / Scion PID add on pack, shows options to view over 326 different engine parameters on the 2GR-FSE. Although many of them work, not all of them do and we don't have enough input to know the cause.
We can also access transmission data and see the oil temperature. This is priceless tool if you intend to DIY transmission Drain and Fill. You'll notice it only takes about 10 minutes of engine run time to exceed the target temperature.
Please list functions that work and what your setup is as well and parameters that do not work as expected. Some of us have different results and we need input to see if it is because of our car model and year or the tools we are using. Here are some examples of PID parameters that work. Like the KCLV used to establish ignition advance works on the my IS-350 but a member with an IS-250 receives bogus data.
Here are some of the sensors. Specifically the transmission oil temperature. Very useful when doing a fluid change.
Here we have Engine Camshaft Position data listed, but it does not work and it does not complain about the version of my Elm327 adapter while other modules that are accessible, pop up an error stating "must have adapter version 2.1 or higher to access this module".
What we don't know is if these faults are specific to our setup (Elm 327 Bluetooth adapter, the car or the PID utility.
These are cheap powerful diagnostic tool that can help you solve problems.
Post away....
*** EDIT, adding links from posts within this thread. ***
From the ISF forum:
Improving KCLV and KFBV.
https://www.clublexus.com/forums/is-...and-power.html
OBD Fusion app and KCLV monitoring
https://www.clublexus.com/forums/is-...-60-oh-my.html
flowrider (01-05-20)
Old 01-05-20, 11:31 AM
flowrider
flowrider's Avatar
Received 1,900 Likes on 1,340 Posts
Yep - I use this:
Amazon Amazon
Along with my Galaxy S9 mounted on a cup holder mount in my LC. My six gauges are speedometer, Tachometer, KCLV, KFV, Coolant Temp, and Voltage.
It's nice that it also works as an OBD scanner for viewing and canceling codes With the OBD LInk device the app is free, though the PIDs are not, but certainly reasonably priced.
Lou
Old 01-05-20, 01:15 PM
2013FSport
2013FSport's Avatar
Originally Posted by flowrider
Yep - I use this:
https://www.amazon.com/ScanTool-OBDLink-Bluetooth-Professional-Diagnostics/dp/B00H9S71LW
Lou
Whaaaaaa?? ^^^ LC has codes??? haha! Hope not!
IIRC there were some mixed reviews on the OBD Link adapters. Rather Spendy as I recall. But another app to add to the list.
Speaking of: Please List all adapters Bluetooth and WiFi that connect and work.
I can't help much as mine is Fleabay knock off Elm327 Bluethooth from about 10 years ago. No clue who actually made it. Its one of those translucent blue ones with red black silver label. It does not show what version is it. But ot works with Torque and Fusion. FWIW: Fusion reports it is not V2.1 compliant.
Old 01-05-20, 02:19 PM
flowrider
flowrider's Avatar
^^^^I've had my OBD Link for a couple of years, Longer than I've had the LC. Haven't erased a code on the LC yet
Lou
Old 01-05-20, 09:40 PM
MikeFig82
MikeFig82's Avatar
After emailing, and sending debug files from my cheap Ebay OBD adapters. Fusion came to the conclusion that they are not equipped to read the necessary Enhanced PIDS.
They recommend me try one of the know compatible adapters here: https://www.obdsoftware.net/scantools
My adapters themselves are as follows.
Bluetooth basic blue dongle V2.1
Bluetooth basic black, and orange sticker housing V4.0
Last the WIFI basic black, and orange sticker housing.
With these 3 I wasn't able to read the KCLV, or KFBV.
Can't Read KCLV, or KFBV
They recommend me to get a known compatible device to read the enhanced PIDs.
I just placed an order from VeePeak for the BLE adapter. Hopefully it will read the knock values correctly once I get it.
2013FSport (04-17-24)
Old 01-06-20, 05:29 AM
redspencer
OG Member
redspencer's Avatar
Hopefully the VeePeak will work for you. I've been using the Viecar 2.0 OBD2 adapter for the past two years and it's had no issues with reading the KCLV and KFV PIDs. I can't comment if the data refresh rate could be better or would be the same using a different adapter or with Bluetooth 4.0 support.
2013FSport (01-06-20)
Old 01-06-20, 07:49 AM
flowrider
flowrider's Avatar
And as stated above my OBDLink device also has no trouble reading KCLV and KVF as well as any other PIDS.
Lou
Old 01-06-20, 07:59 AM
2013FSport
2013FSport's Avatar
Lou
Mike's IS-250 info is here....
https://www.clublexus.com/forums/per...rn-values.html
Reports this;
Ever seen anything like that?
My guess is it is not the adapter. Usually it just doesn't work at all. We need other 250 owners to chime in....
Old 01-06-20, 08:10 AM
MikeFig82
MikeFig82's Avatar
Reports this;
It has to be the adapters. While using the V4.0 I was able to get the correct readings for a few seconds. That being said I had trouble with it connecting properly it would crash while scanning for supported PIDs.
The Ver2.1, and WIFI adapters work for the exception of reading knock. All other basic PIDs work well fuel trims, temps. I've compared them to my cable scan tool and they are dead on.
Old 01-06-20, 08:17 AM
2013FSport
2013FSport's Avatar
^^ OK, I was unaware that any of your adapters ever reported anything usable. Good to know.
Can someone with V2.1 load a gauge with any of the VVT cam angle data?
Thanks in advance!
Old 01-06-20, 09:05 AM
MikeFig82
MikeFig82's Avatar
Thanks in advance!
2013Fsport,
If you can add this link to your first post. I think it would benefit the IS250 owners as well. I've contacted a few members, and they are still in the dark about benefits of KCLV, and KFBV.
Thanks,
Mike
Old 01-06-20, 10:02 AM
flowrider
flowrider's Avatar
Might want this thread in the ISF forum:
Lou
The following 2 users liked this post by flowrider:
2013FSport (01-06-20), MikeFig82 (01-06-20)
Old 01-06-20, 01:31 PM
2013FSport
2013FSport's Avatar
2013Fsport,
Thanks,
Mike
Lou
Guys,
Both are good links and I'll bump them. Thanks...
That said, the primary goal is how to collect data and what hardware and PIDs work and which don't so people don't waste their time and money... still, post away!
MikeFig82 (01-10-20)
Old 01-10-20, 08:05 PM
MikeFig82
MikeFig82's Avatar
Update:
Received the VEEPEAK BLE. I can view my KCLV, KFBV correctly now. I reset the ECU running SHELL Premium 93. It may, or may not climb any higher. Hopefully shooting for 25.2
Old 01-10-20, 09:29 PM
flowrider
flowrider's Avatar
^^^^I run KCLV with one decimal point. It's pretty accurate Same with the speedometer.
Lou
Quick Reply: OBD Apps | Torque Pro & OBD Fusion with PID pack
