2009 IS350 Advice
First, the Carfax report obviously. Then the previous Lexus maintenance history, available through Lexus.com once you create a log-in and set your VIN to the vehicle's VIN that you're looking to purchase. Post your findings on what out-of-the-ordinary items you find on that report.
Other than doing the usual test drive, walk-around, and optional pre-purchase inspection, listen out for odd sounds from the engine bay and monitor your trans for smooth shifts during the test drive.
Should be a good purchase though, if everything checks out! Join the 350 club...you won't regret it!
Replaced mirror assemblies at 96K
Airbag Module, high fuel pressure sensor and gasket at 91K
Right side headlight assembly at 82K
water pump assembly gasket replaced at 71K
VVT Actuator gear at 60K
Fuel Induction service done at 26K
Regular scheduled maintenance done at 5K, 10K, 15K, 20K, 25K, 30K, 35K, 40K, 45K, 50K, 60K, 65K, 70K, 80K, 85K.
Vehicle has 108K miles. Everything look reasonable?
Replaced fuel delivery pipe sub-assembly at 100K
AMIRZA786 (02-04-20)
No worries with this one. All of my Lexus vehicles have over 100k...one over 200k! I would take any of them on a road trip tomorrow. As previously mentioned you can't go wrong with a well taken care of 2IS. Buy it!
Try this: buy two cans of Yamaha Ring Free and pour one in the fuel tank and fill to 3/4. Run the crap out of it! Pull long steep hills at RPM making it work at temperature. Repeat. Change the oil to your favorite conventional dino fluid; none synthetic.
Report back in 5k....
Money says, it cuts oil loss in half or even better.
How is the car used?
/return....
As part of my pre-purchase inspection; I have them get the car in the air and do my own inspection;
rust
torn cv boots
torn ball joint boots
oil and coolant leaks
trans leaks
diff leaks
Damage from driving over ????? and again, inspection of drip rails for clamp marks.
Do keep in mind Car Flakes is a warm fuzzy only. Anyone can have parts painted out of pocket.
Having the car inside under florescent lights AND looking from the bottom up allows you to see things others miss and look at paint shades for mismatches from panel to panel. Also look for overspray inside of doors, fenders, trunk, hood. I spect all door gaps, hood gaps, trunk gaps and most importantly; the sound they make when being closed.
Too many years in the auto industry. I can be thorough in a short time...
rust
torn cv boots
trans leaks
diff leaks
neil rozz
25
11-03-07 01:21 PM
