Transmission Issues
Recently I had a transmission Code come up P2714. Which indicated a bad pressure solenoid. I had access to another transmission valve body so I swapped the valve bodies out. Now car will not move forward or backwards. Is there something I am missing or does new valve body have to be programmed. Any Ideas?
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Hi there LowCash,
I am just a noob on here, but in my travels across the forum I have heard of reseting the ECU, now im not sure if it will help you at all but I thought its worth a try.
the short of it is to disconnect the battery for a while then reconnect it, wait some more then start the car up and leave it alone for a while. apparently it will idle rough then will relearn the engine and correct its self.
I am no expert though and suggest you look up how to reset the ECU first just to get a better understanding.
Here is the link - https://www.clublexus.com/how-tos/a/...our-ecu-363500
Let me know how it goes.
your friendly noob,
Scoots
your friendly noob,
Scoots
Scoots (02-20-20)
donmcc
03-31-13 03:55 PM
