Will these headlights fit my 2010 Is350?
Hello all,
I've had a crack in my passenger headlight and it has burned my headlight out due to moisture. I've been putting this off for a while. I found a good deal for two lights for $100 (still waiting to see if they are HID w/ AFS) but they are for a 2006 is250. Will these fit my 2010?
Scoots (02-20-20)
Hi there Topher350,
I am just a noob on this forum but its my understanding that the 2IS range has remained largely unchanged from the 2005 to the 2012 model.
Im looking at replacing mine with the Vland set. on the website they only have one set for the entire range.
- https://www.vland-carlamp.com/index....ch=Lexus+is250
I have also got you the link on how to replace your headlights. I had a quick skim through to see if there are any model refresh issues, but couldn't find any.
- https://www.clublexus.com/how-tos/a/...-lights-362786
unless you're on about fitting the AFS headlights and having the AFS system work on a version that didn't come with it from the factory, I have no clue about that sorry.
Your friendly noob,
Scoots.
Your friendly noob,
Scoots.
Hello all,
Scoots (02-18-20)
Scoots (02-20-20)
For reference, assuming you have factory HIDs, your ballast is likely the part that has gone bad as they don't like moisture at all so you won't really be able to reuse it. If you're buying headlights that don't include them already, it's likely you'll have to buy one from eBay/Amazon/wherever.
Scoots (02-20-20)
