Transmission Flush
This summer the 350 will be at 95,000 and will be done.
Plan is a one time event that replaces all the fluid at one time!
How? I have used pan and that pan has a hole in it where the filter inlet attaches to the valve body. I'm going to feed the pickup tube new fluid allowing the torque converter to dump its contents into the pan without mixing old and new.
So, the trans will get 6 quarts of new fluid directly, without mixing. Once consumed, engine off, install new filter, pan and fill as needed checking at designated temperature.
If this goes to plan, maybe I'll ship the setup out for a nominal fee. Time wise it won't take long at all and the benefit is all fresh fluid without having to repeat the process of blocking the car, cooling it overnight repeatedly, and still having mixed fluid when done.
I'll keep you posted....
I do have one item that caught my eye... OBD Fusion thinks the transmission temp goes up way quicker than I believe, so I need to get techstream on there and verify a few cold starts and see if it's telling the truth.
Bottom line is mixing bothers me. I just want fresh fluid in there.....
surferbum
RX - 3rd Gen (2010-2015)
09-26-11 09:43 AM
fantastic1
Performance & Maintenance
08-22-11 05:40 PM
